Markku Posted January 22, 2025 Report Posted January 22, 2025 I am replacing the #4 push rod exhaust tube on my IO360-A3B6 due to oil cooler baffle cutting into the tube. Easy to remove the 2 springs at the case part # 15H21201, but I am struggling to rotate the springs into position. Anyone have a trick for doing this? Thanks
N201MKTurbo Posted January 28, 2025 Report Posted January 28, 2025 Perseverance and bloody fingers. 1
N201MKTurbo Posted January 28, 2025 Report Posted January 28, 2025 The pushrod springs on the Lycomings are not their best ideas…
N201MKTurbo Posted January 28, 2025 Report Posted January 28, 2025 Actually, if you lube the seals with DC4, you can get the springs to line up and click together with the tabs pointing up, then you can rotate the springs and the tubes till the spring tabs point to the other tube. 1
MB65E Posted January 28, 2025 Report Posted January 28, 2025 Wrap the tabs/holes with .040 safety wire and support the tube with a wrench. Rip and pull hard quickly. A little lube on the ramps works well too -Matt
Markku Posted February 3, 2025 Author Report Posted February 3, 2025 I came up with a trick that worked beautifully. I took a 4" piece of gray 3/4" pvc tubing and split it in half on my bandsaw. I then placed duct tape on the inside of the two cut pieces. The duct tape adds a none slip feature. I put the two halves around the push rod shroud and with a pair of pliers clamped the two halves and rotated the shroud until the springs snapped into the notches. The long end of the spring with the hole rested against the case and kept it from rotating. The Lycoming manual just says to rotate the shroud until the spring notch locks into place. Easier said than done. Thanks for all the replies. 2 1
