Bringing my new acclaim home and I now "HAVE" a different prop.
PREP
Prop has been installed!
Unfortunately the wiring harness for the surefly did not arrive so I didn’t get the electronic ignition installed. But there was plenty more to do.
In this visit with Brian K we got a good amount done.
1.  Installed new prop and spinner.
2.  Changed all exterior lighting to LED.
3.  Two new magnetos and timing adjusted.
4.  Chafe tape on cowling replaced.
5.  Rerigged landing gear for door adjustments.
6.  Flap actuator adjustment for correct position indications.
7.  Bled and changed brake fluid.
8.  Changed all landing gear pucks.
9.  Installed bob fields inflatable door seal.
10.  Changed landing light lenses.
I almost wish that I had flown the plane with just the prop and done the door seal later.
Both of these items were done for noise reduction, and both appear to have made a significant difference.  The flight back from Texas was almost 5 decibels quieter which is an enormous improvement.
the prop on the ground sounds really different, but the noise in cruise is extremely quiet. The prop response is much quicker and while the advertised weight savings of 28# is a flat out lie, there was an actual 18# weight saving which makes a pretty big difference in landing. I also notice that the elevator is about 1/2” less deflection in cruise and it appears to be about 3kts faster in cruise.
The lower cowling is a little more difficult to remove and replace, but still easier than an ovation, and I can still do it alone.
The TKS slinger ring is also a MUCH design than the hartzell and  works much better.
I am very happy with the prop and am thoroughly enjoying the restoration process.
I will make a separate post regarding the door seal install, for any of those interested in installing. I believe after doing one, I could do it over again in less than 3 hours. It is incredibly simple once you know the shortcuts.
Coming items….
updated fuel caps to new style.
surefly mag install.
new glass all the way around.
New interior
reseal of tanks
new landing gear doors on right side.
brake system overhaul.
new paint.
pending/contemplating
type S conversion.
corrosion X treatment.
motor mounts.
new panel cutout to install 275 in center and push mfd over.
earthX batteries
That is a very interesting idea to which you allude with the panel:
Replacing backups with a GI-275 in the center. It's funny I always hear about the STC limitation with the G1000 but I rarely hear about big panel mods.
Someone theorized that you might be able to cross feed data between the 275 and the G1000, and get better communication with other Garmin devices that way. (I know Lance is looking at a more direct flightstream based mod right now...)
You could also drop a second unit in HSI mode underneath and get a more full featured backup set... You also probably know this, but if you put in a Garmin USB plug you can also use that for updates.
Looks like it's shaping up as a really custom plane. Vaguely envious of your slight aft CG.
Ray it is badass, I’d love to know the difference the four blade makes, you’ll end up with the nastiest Acclaim around. It’ll look fast just sitting on the ramp. We need a turbo or all Mooney flyin somewhere some weekend. Be cool to see 40-50 badass planes sitting together.
The only difference in sound is on the ground it whistles a little and sounds choppier than the three blade. In cruise the noise isn’t very different, except it is quieter. Not sure how much is the door seal and how much is prop.
Expand
Im pretty sure it doesn’t cross talk to the AP or EIS at all. Maybe the transponder. I just think it’s a more practical location in your were to ever need it…
it’s a lot of work, that doesn’t really add value and questionable necessity.
It would look cool and I don’t suspect the mfd is that much harder to reach in our planes.
Expand
Yeah, the Mooney backup gauges are not in a good location.  The best I’ve experienced is in the Diamond G1000 planes: right across the top.
The big scimitar MT prop on the DA40 XLS also whistles.  I always thought it was cool.
-dan
It isn’t an unpleasant sound at all.  I think any time your plane sounds different it seems acute at first. The da42 and the diamond star also whistl, and both had mt props.
Expand
I would love to see a deck full of turbo mooney’s!
  • Schllc changed the title to Bringing my new acclaim home and I now "HAVE" a different prop.
  • 3 weeks later...
Probably should check with @Pmaxwell at Don Maxwell.
If it were more than a couple AMU's, I wouldn't bother.  Speed gain is not meaningful, and the stall is 1ish KCAS higher.
-dan
  On 3/9/2025 at 6:06 PM, mhoffman said:
So i currently have a 2007 Acclaim, do you know any shops that do the Type S conversion in 2025 also do you think it would be worth the $ ?
Expand
The conversion is subject to parts availability.
the most expensive element is the prop, the second is the nose gear truss and doors, which are not available.
the flap gap seals and the cowl vanes are not expensive and available.
the last item is the removal of the hinge covers.
I think the prop is the bulk of the speed gain, and the others are a benefit in the higher altitudes.
I already changed my prop, and am about to paint the plane so I installed rhe items available.  It was more advantageous financially bc of everything I’m already doing to the plane.
I’ll be able to give a p-rep once the work is done.
  • 3 weeks later...
I added the flap seals to my non-S 2007 Acclaim and it was worth an honest 3-4 kts @ 15,000.  FYI I have FIKI so YMMV.
