Jason 1996 MSE Posted October 13, 2024 Report Posted October 13, 2024 I just purchased a 1996 J. During transition training when we ran the King A/P preflight check the lights blinked as planned. My instructor thought there was also supposed to be audible beeps to confirm a successful test although I couldn’t find this in the POH A/P preflight instructions. Any other J owners out there with KAP-150 can confirm if your autopilot ‘beeps’ at preflight. Thanks. Quote
PeteMc Posted October 13, 2024 Report Posted October 13, 2024 8 minutes ago, Jason 1996 MSE said: I couldn’t find this in the POH A/P preflight instructions. It's not in the POH, it's in the King KFC 150 manual. I have a KFC 200 and it's basically the same. Here's a link to download the manual: https://www.bendixking.com/content/dam/bendixking/en/documents/downloads/006-08377-0001_1-kap-150-ki-525a-pilot-s-guide.pdf Here's the key section: To perform a test - momentarily push the test button: 1. All annunciator lights, the trim light and autopilot light will illuminate. 2. The trim light will flash 4 times. 3. The annunciator legends will be blank, an aural tone will beep (approx. 6 times) and the "AP light will flash (approx. 12-13 times) and go off. (If the AP light fails to flash you will be unable to engage the autopilot.) 4. The KC 191 display will go blank. 1 Quote
PT20J Posted October 14, 2024 Report Posted October 14, 2024 KAP150 Pilots Guide.pdf Sonalert is in the overhead. You should also hear it when you disengage the autopilot. If not, I’d check the sonalert. 1 Quote
0TreeLemur Posted October 14, 2024 Report Posted October 14, 2024 The KFC-150 in my J beeps five times if all's well -or- forever (or until I pull the CB) if something causes it to not pass its self test. This happens for instance if somehow the Elec. Trim power switch is inadvertently switched off. That's actually a good way to test your sonalert. 1 Quote
