Beau Posted August 17, 2024 Report Posted August 17, 2024 MY GARMIN 530 WAAS SHUT DOWN AT AUSTIN EXECUTIVE LAST WEEK. HELP! I GOT A GREEN LIGHT FROM EXECUTIVE TOWER AND GOT IT BACK TO HOUSTON. THEN THE RADIO STARTED WORKING AGAIN. I DID NOTICE THAT A BLACK HORSE SHOE SHAPED RING ABOUT 1/8 INCHES WIDE APPEARED ON THE SCREEN. IT HAS NOT GONE AWAY. CAN ANYONE RECOMMEND AN AVIONICS SHOP IN TEXAS PREFERABLY CLOSE TO HOUSTON? CAN THIS 530 BE REPAIRED OR IS TIME FOR A NEW ONE? THIS GARMIN 530 IS ABOUT 15 YEARS OLD.
BlueSky247 Posted August 17, 2024 Report Posted August 17, 2024 As I understand it, If the display goes bad, those are not able to be repaired. You may want to look into doing the avidyne ifd540 slide in replacement. 2
Ragsf15e Posted August 17, 2024 Report Posted August 17, 2024 22 minutes ago, Beau said: MY GARMIN 530 WAAS SHUT DOWN AT AUSTIN EXECUTIVE LAST WEEK. HELP! I GOT A GREEN LIGHT FROM EXECUTIVE TOWER AND GOT IT BACK TO HOUSTON. THEN THE RADIO STARTED WORKING AGAIN. I DID NOTICE THAT A BLACK HORSE SHOE SHAPED RING ABOUT 1/8 INCHES WIDE APPEARED ON THE SCREEN. IT HAS NOT GONE AWAY. CAN ANYONE RECOMMEND AN AVIONICS SHOP IN TEXAS PREFERABLY CLOSE TO HOUSTON? CAN THIS 530 BE REPAIRED OR IS TIME FOR A NEW ONE? THIS GARMIN 530 IS ABOUT 15 YEARS OLD. I would contact jake bevan. They can do some repairs. Also, I think those have an internal fan? @Avionics Source might be the right user name? 1
LANCECASPER Posted August 17, 2024 Report Posted August 17, 2024 12 minutes ago, Ragsf15e said: I would contact jake bevan. They can do some repairs. Also, I think those have an internal fan? @Avionics Source might be the right user name? @Jake@BevanAviation 1
Ragsf15e Posted August 17, 2024 Report Posted August 17, 2024 3 minutes ago, LANCECASPER said: @Jake@BevanAviation Ahh, much better. Thanks!
McMooney Posted August 17, 2024 Report Posted August 17, 2024 Little Far but i can't stop recommending HorizonAviation @ KTYS
Bobaran Posted August 17, 2024 Report Posted August 17, 2024 Buy or borrow a hand held radio to get you home? 1
Jake@BevanAviation Posted August 17, 2024 Report Posted August 17, 2024 Give us a call Monday and ask for Zach or Mike. The black horse shoe sound like the display backlight and yes there is a fan that can fail. 3
LANCECASPER Posted August 18, 2024 Report Posted August 18, 2024 4 hours ago, Bobaran said: Buy or borrow a hand held radio to get you home? You’re fortunate if you can transmit to the person sitting next to you in the cockpit with a handheld. On most of them you can receive a little but transmitting from inside the cockpit without being hooked up to an external antenna is not going to help much. Even though his profile says M20R, @Beau has an M20M, all of which had two COM radios from the factory. @Beau doesn’t say whether he tried that. 1
BlueSky247 Posted August 18, 2024 Report Posted August 18, 2024 Please let us know how things turn out on this. It would be good to know if it is able to be repaired.
