M20F Posted August 9, 2024 Report Posted August 9, 2024 Apologies for inserting a picture the website wasn’t liking copy/paste formatting Looks like long range tanks are back 1 Quote
shawnd Posted August 9, 2024 Report Posted August 9, 2024 Nice. Which shop is this? Will have to add this to the wish list. Quote
kortopates Posted August 9, 2024 Report Posted August 9, 2024 1 minute ago, shawnd said: Nice. Which shop is this? Will have to add this to the wish list. Maxwells - they own the STC now and as far as I know aren't yet making installation available to others - which is a bigger deal to our European and Australian friends. But that could change any time. Quote
LANCECASPER Posted August 9, 2024 Report Posted August 9, 2024 2 minutes ago, shawnd said: Nice. Which shop is this? Will have to add this to the wish list. Don Maxwell has the Jose Monroy STC for long range tanks: https://www.donmaxwell.com/ Jose did the tanks on a Bravo I owned back in 1997. Back then it was around $7000 installed. Best upgrade on a Mooney in my opinion - gives you a lot of flexibility. 2 Quote
Fly Boomer Posted August 9, 2024 Report Posted August 9, 2024 14 minutes ago, shawnd said: Nice. Which shop is this? Will have to add this to the wish list. It's a bit difficult to use, but the FAA database says: STC Number : SA1913SO Description: Auxiliary fuel cells STC Holder: KMAX Aero LLC I have not heard of KMAX, but it sounds like a Maxwell derivative. Quote
LANCECASPER Posted August 9, 2024 Report Posted August 9, 2024 9 minutes ago, Fly Boomer said: It's a bit difficult to use, but the FAA database says: STC Number : SA1913SO Description: Auxiliary fuel cells STC Holder: KMAX Aero LLC I have not heard of KMAX, but it sounds like a Maxwell derivative. https://www.donmaxwell.com/copy-of-gmax-aircraft-sales Quote
Fly Boomer Posted August 9, 2024 Report Posted August 9, 2024 4 minutes ago, LANCECASPER said: https://www.donmaxwell.com/copy-of-gmax-aircraft-sales Gmax for jimmy Garrison, Kmax for Kellen Kester Quote
IvanP Posted August 9, 2024 Report Posted August 9, 2024 I have this mod on my Bravo, but do not find it particularly useful (came with the plane). With full fuel (118 gal), I would be at max GW with me as the only occupant of the plane with no allowance for luggage and pushing the forward CG limit. I know, I should lose some weight :). While full tanks would give me apmple fuel reserve, it would also exceed my bladder capacity (there are some things I just refuse to do in my Mooney unless absolutely necessary and using LittleJohn or equivalent is one of them). My typical mission is 2 adults with 30-50 lbs of baggage, leaving me with about 85 galons of fuel to stay within the W/B limits. So far, I have not had the opportunty to take advantage of the additional fuel capacity on this plane, but I have only had it for little of 1 year. However, folks with different mission profiles and larger bladders may find it worth the money. Quote
Fly Boomer Posted August 9, 2024 Report Posted August 9, 2024 2 minutes ago, IvanP said: I have this mod on my Bravo, but do not find it particularly useful It is like the turbo or ice protection--it offers options you would not otherwise have. Quote
IvanP Posted August 9, 2024 Report Posted August 9, 2024 Yes, I love the turbo. It was the main reason I got the Bravo. Quote
Pinecone Posted August 9, 2024 Report Posted August 9, 2024 43 minutes ago, IvanP said: I have this mod on my Bravo, but do not find it particularly useful (came with the plane). With full fuel (118 gal), I would be at max GW with me as the only occupant of the plane with no allowance for luggage and pushing the forward CG limit. I know, I should lose some weight :). While full tanks would give me apmple fuel reserve, it would also exceed my bladder capacity (there are some things I just refuse to do in my Mooney unless absolutely necessary and using LittleJohn or equivalent is one of them). My typical mission is 2 adults with 30-50 lbs of baggage, leaving me with about 85 galons of fuel to stay within the W/B limits. So far, I have not had the opportunty to take advantage of the additional fuel capacity on this plane, but I have only had it for little of 1 year. However, folks with different mission profiles and larger bladders may find it worth the money. Because you picked the wront Turbo Mooney. My 252/Encore is 104 gallons. I can carry 2 people with full fuel. Or me and a lot of luggage. Flexibility 2 Quote
IvanP Posted August 10, 2024 Report Posted August 10, 2024 You are probably right. But either way, I run out of bladder capacity before I run out of fuel even in the thirsty Bravo. The days when I was able and willing to do 5+ hour legs are history. Now it is 3-4 hours max. The joys of getting old. Quote
jetdriven Posted August 10, 2024 Report Posted August 10, 2024 You can pee in a bottle, but you can’t run a plane on air. They’ve tried. 1 Quote
BlueSky247 Posted August 10, 2024 Report Posted August 10, 2024 Wish they could reseal the regular tanks while they are at it. And install speed brakes… Quote
shawnd Posted August 10, 2024 Report Posted August 10, 2024 23 minutes ago, BlueSky247 said: Wish they could reseal the regular tanks while they are at it. And install speed brakes… And after they are done with those, spray corrosion X for full service. 1 Quote
M20F Posted August 10, 2024 Author Report Posted August 10, 2024 As the original poster I want to make clear that this STC does not come with Jose’s “relief tube”. Hope Jose is doing well and miss his posts. 1 Quote
IvanP Posted August 10, 2024 Report Posted August 10, 2024 (edited) I bet they can do it so long as you are willing to part with appropriate number of AMUs at the end. The magic power of money keeps our planes airborne and airworthy, unless you need some parts made of unobtainium, like the dreaded tubo V-band clamp for Bravos. Edited August 10, 2024 by IvanP Quote
M20F Posted August 10, 2024 Author Report Posted August 10, 2024 16 hours ago, kortopates said: aren't yet making installation available to others - which is a bigger deal to our European and Australian friends. But that could change any time. In the email they clarify the FAA allows an STC holder to install their own parts. A kit that a 3rd party installs however requires PMA approval which they don’t have yet. 1 Quote
McMooney Posted August 10, 2024 Report Posted August 10, 2024 really wish it wasn't so damn expensive, planning on installing these in the next 2 years. Quote
M20F Posted August 10, 2024 Author Report Posted August 10, 2024 21 minutes ago, McMooney said: really wish it wasn't so damn expensive, planning on installing these in the next 2 years. In the grand scheme of things aviation seems pretty cheap to me. I can’t wait to get them and spend 9hrs at FL250! 1 Quote
MikeOH Posted August 10, 2024 Report Posted August 10, 2024 Until I can find a way to upgrade my 3.5 hour bladder, no need for a 9 hour aircraft bladder! 2 Quote
Danb Posted August 10, 2024 Report Posted August 10, 2024 It was the first and best modification I did to my Bravo in 2006,:my Bravo had useful load around 1010 me not being a big guy along with wife we flew numerous 1000+ mile trips which I sorely miss in the Acclaim. The Acclaim has about 140* less useful load bummer, why ? Quote
M20F-1968 Posted August 11, 2024 Report Posted August 11, 2024 I have a highly modified M20F which is now essentially a J. It has speed brakes and carries 90 gallons of fuel due to the Monroy tanks. It range is over 1200 miles, with reserves, and longer LOP. It allows longer range, and allows you to purchase more cheap fuel when available. I burn 11 gallons per hour at 160-175 kys depending upon altitude due to a Rayay Turbonormalizer. The combination of the long-range tanks and turbonormalizer turns the F model into an airplane that is more capable than the J and challenges the 231. John Breda 2 Quote
Fritz1 Posted August 11, 2024 Report Posted August 11, 2024 thought about it when I bought the Bravo, gives you an option, the Bravo topped off to the fuel cap O-rings has 102 gal usable, I keep the tanks full, so carrying more than one passenger I have to de-fuel, with long range tanks even more so, UL with TKS tank full and rear seats out is about 990lb, figured I was not going across the Atlantic so I passed on the long range tanks, very useful though for somebody who goes strictly by themselves in the Bravo Quote
Pinecone Posted August 11, 2024 Report Posted August 11, 2024 Solution for bladder range. Better than a bottle as it gels the liquid, so no spills and it also deodorizes. https://www.amazon.com/TravelJohn-66892-18-Pack-Disposable-Urinals/dp/B00C6U6ULK/ref=asc_df_B00C6U6ULK/?tag=hyprod-20&linkCode=df0&hvadid=692875362841&hvpos=&hvnetw=g&hvrand=9424209399360381790&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9051570&hvtargid=pla-2281435181418&psc=1&mcid=1ced38acf394329e8b8ec099650f7c9a&hvocijid=9424209399360381790-B00C6U6ULK-&hvexpln=73&gad_source=1 1 Quote
