Dream to fly Posted April 13, 2024 Report Posted April 13, 2024 Does anyone know where to get new bushings for the main landing gear retract links. They are 3/8in ID x 1/2in OD. I can buy a new link but doesn't come with the bushings.
47U Posted April 14, 2024 Report Posted April 14, 2024 4 hours ago, Dream to fly said: Does anyone know where to get new bushings for the main landing gear retract links. Check with LASAR. Gather up the part numbers and give Heather a call. You might check their website to see if they are in stock. They won’t be cheap, however. About 15 years ago I replaced a handful of gear bushings and they were .3 amu. But, it fixed the main gear from fully retracting and hanging an inch below the wheel well opening. If you call around other MSCs might have better prices. And, you can type the part number into the search window on controller.com and one of the parts warehouses might have bushings in surplus stock.
Dream to fly Posted April 14, 2024 Author Report Posted April 14, 2024 Thanks, for the replies. I will call Monday. I totally forgot about LASAR.
65MooneyPilot Posted April 14, 2024 Report Posted April 14, 2024 LASAR’s website for parts in stock is not always correct. Sometimes it says no stock and when you call they are in stock. Good luck 1
