t42dor Posted April 5, 2024 Report Posted April 5, 2024 i have a m20j and my spinner is cracked i want to replace it or repair it does anybody knows where i can get one or if its possible to repair the old one thank you Quote
N201MKTurbo Posted April 5, 2024 Report Posted April 5, 2024 There are a couple of companies that repair spinners. New ones are available if you have the time and money. I would check the salvage guys. Quote
0TreeLemur Posted April 6, 2024 Report Posted April 6, 2024 @t42dor I have an extra spinner. During the annual on our J in January, they discovered a cracked interior bulkhead in my spinner. Needing an interior bulkhead, I bought a spinner that had a good one 'cause that's the deal that was made. So I have an extra spinner w/o a bulkhead. I'd sell it and you could move your bulkhead. It's for a McCauley 2-blade prop. If you are interested I'll send photos. It's unpainted aluminum with a few scratches but looks serviceable. Quote
Paul Thomas Posted April 6, 2024 Report Posted April 6, 2024 Mine was welded; depending on the shop, it may come out looking new or the weld may be visible. OTreeLemur offer of may get you back in the air faster, be competitively priced, and you'd have a perfect spinner. Does the bulkhead go right on the prop or is there an additional retaining ring to make it is tighter fit? Quote
egarcia77035 Posted April 6, 2024 Report Posted April 6, 2024 I have a spinner w bulkhead. Let me check if the one pulled from my E model with lo presti mod will fit. I'll send you the part number when I return Tuesday. Quote
RoundTwo Posted April 9, 2024 Report Posted April 9, 2024 I On 4/8/2024 at 9:23 PM, OR75 said: Will be putting them on eBay Expand Is that a scratch or crack in the next to last picture? Quote
OR75 Posted April 9, 2024 Report Posted April 9, 2024 On 4/9/2024 at 2:25 PM, RoundTwo said: I Is that a scratch or crack in the next to last picture? Expand crack that has not changed in 10 years. It ends at the screw hole so drill stopped Quote
t42dor Posted April 15, 2024 Author Report Posted April 15, 2024 this is what I actually need i guess it’s the bulkhead part number: 680031-037 Quote
t42dor Posted April 15, 2024 Author Report Posted April 15, 2024 On 4/6/2024 at 11:06 PM, egarcia77035 said: I have a spinner w bulkhead. Let me check if the one pulled from my E model with lo presti mod will fit. I'll send you the part number when I return Tuesday. Expand thank you this is the part number: 680031-037 Quote
