Hello everyone,
has anyone else had issues with the Oxygen System in the 231?
Specifically the regulator and/or the oxygen compensating unit of the oxygen system? The part number for the OCU is 801765-00.
Mine has worked really well. The valve leaked years ago but that was fixed and it can sit for months without losing pressure. Understand that there is a change of the pressure reading by the gauge as OAT changes. Pressure goes up on a hot day and down when it is cold. Here in MN the difference can be substantial. But it does not mean there is a problem with the system.
It’s a Scott/Avox altitude compensating regulator - the altitude compensator can be very finicky and is expensive to replace if it’s bad.  When was the last time the system was bench tested?   Do you have a flow meter that you use with your cannula?   That will tell you f you are getting enough flow….
I've had problems with most of the system, but not the regulator.  It's a pretty simple system actually, just lots of places leaks can develop.  Currently have all the leaks fixed.
What's the problem with yours?
