Mcstealth Posted January 1, 2024 Report Posted January 1, 2024 Good morning. What do you think could be the problem?: The symptoms are the door will not open, obviously. The movement "up" is at a snails pace, the chains barely moving. The motor is spinning and sounds normal. The "down" movement seems normal, but I am assuming that is because of the weight of the door itself. No mechanical grinding or obvious bad noises of any kind.
Fly Boomer Posted January 1, 2024 Report Posted January 1, 2024 Looks like there is a gear box. Can it be lubricated?
N201MKTurbo Posted January 1, 2024 Report Posted January 1, 2024 There is probably a coupling between the motor and gearbox. I would check that it isn’t loose and slipping. 1
FoxMike Posted January 2, 2024 Report Posted January 2, 2024 Brushes in the motor or low voltage into the motor.
N201MKTurbo Posted January 2, 2024 Report Posted January 2, 2024 2 hours ago, FoxMike said: Brushes in the motor or low voltage into the motor. It looks like an AC induction motor. They don’t have brushes.
N201MKTurbo Posted January 2, 2024 Report Posted January 2, 2024 The lift mechanism is coupled to the box on the side. It probably has the limit switches. I would look in there.
1964-M20E Posted January 2, 2024 Report Posted January 2, 2024 You say the door is not moving then say movement is slow going up????? pop the gear box cover off and see what is and isn't moving. Then as above make sure everything, gear box, wheels, strap roller bearings (pillar blocks probably about 10 of them the length of the door) are well lubricated.
Mcstealth Posted January 3, 2024 Author Report Posted January 3, 2024 (edited) On 1/2/2024 at 5:52 AM, 1964-M20E said: You say the door is not moving then say movement is slow going up????? pop the gear box cover off and see what is and isn't moving. Then as above make sure everything, gear box, wheels, strap roller bearings (pillar blocks probably about 10 of them the length of the door) are well lubricated. The motor is turning, the door does "move" up, but I am talking millimeters here. We took off the capacitor cover. There are two capacitors and one is rusted through. Going to replace it as a matter of good practice. See if that helps. Edited January 4, 2024 by Mcstealth
A64Pilot Posted January 4, 2024 Report Posted January 4, 2024 19 hours ago, Mcstealth said: The motor is turning, the door do "move" up, but I am talking millimeters here. We took off the capacitor cover. There are two capacitors and one is rusted through. Going to replace it as a matter of good practice. See if that helps. Shouldn’t but what the heck it’s rusted easy and inexpensive, due to the rust it ought to be replaced anyway. Assuming the motor sounds normal, my bet is the drive is slipping, sheared key or something, it ought to be real easy to see. I don’t think it’s the gears, if you broke a gear you can tell from the noise it makes, but it could be a gear slipping on its shaft 1
Mooneymite Posted January 4, 2024 Report Posted January 4, 2024 Did you contact the door manufacturer? 1
Mcstealth Posted January 4, 2024 Author Report Posted January 4, 2024 3 hours ago, Mooneymite said: Did you contact the door manufacturer? No longer in business. I did call a company named Schweise. They were very helpful even though it is not one of their doors.
Mcstealth Posted January 12, 2024 Author Report Posted January 12, 2024 23 hours ago, A64Pilot said: Well what is it? They sent the motor off and break to be rebuilt. got the assembly back last Friday. Put it on and it did not work They did some more tracing and found out. The actual switch on and off switch was bad. It is an old style switch that is not found everywhere. But they should be back today to install it. the saga continues.
A64Pilot Posted January 13, 2024 Report Posted January 13, 2024 So the motor wasn’t running? Is your airplane trapped until then?
Mcstealth Posted January 13, 2024 Author Report Posted January 13, 2024 (edited) 46 minutes ago, A64Pilot said: So the motor wasn’t running? Is your airplane trapped until then? Yes. Everything has been trapped for two full weeks now. The motor did make noise when the tech's came out. Slightly perturbed but only just, because we probably could have caught the on/off switch problem if we were not so short sited and lacked thoughtfulness. Yucky capacitors, wonky motor, should have told us to keep poking. Edited January 13, 2024 by Mcstealth
A64Pilot Posted January 15, 2024 Report Posted January 15, 2024 Just curious, is this your hangar as in you own it, or is this rented?
Mcstealth Posted January 19, 2024 Author Report Posted January 19, 2024 On 1/14/2024 at 6:18 PM, A64Pilot said: Just curious, is this your hangar as in you own it, or is this rented? It is owned. Finally, the little piss-ant threeway toggle switch, something that looks like I could have found at Grainger, showed up. The damn hangar is opening again. Now the gears are grinding. Grrrrrrr 1
