rotorman Posted June 12, 2023 Report Posted June 12, 2023 I'm planning to overhaul my Dukes pump at Aeromotors. My guess is they don't supply new O rings with the overhaul. Any idea where to source them. I looks like each elbow fitting has two o rings. One rubber and one made from a material I don't recognize . Any ideas on where to source these? Mine are in good shape but I would prefer new ones. Quote
rotorman Posted July 3, 2023 Author Report Posted July 3, 2023 On 6/12/2023 at 4:07 PM, rotorman said: I'm planning to overhaul my Dukes pump at Aeromotors. My guess is they don't supply new O rings with the overhaul. Any idea where to source them. I looks like each elbow fitting has two o rings. One rubber and one made from a material I don't recognize . Any ideas on where to source these? Mine are in good shape but I would prefer new ones. If you ask for them they will send them. I just received the rebuilt pump. They received it on a Friday and had it shipped it out the following Thur. $500. Can't beat that kind of service. Is it legal for a pilot to install the pump? Two fuel lines and a pair of wires. My guess is no. Quote
EricJ Posted July 4, 2023 Report Posted July 4, 2023 2 hours ago, rotorman said: If you ask for them they will send them. I just received the rebuilt pump. They received it on a Friday and had it shipped it out the following Thur. $500. Can't beat that kind of service. Is it legal for a pilot to install the pump? Two fuel lines and a pair of wires. My guess is no. It does not qualify as Preventive Maintenance, but if you have an A&P willing to supervise/inspect and sign it off you can do the work yourself. Quote
N201MKTurbo Posted July 4, 2023 Report Posted July 4, 2023 3 hours ago, rotorman said: If you ask for them they will send them. I just received the rebuilt pump. They received it on a Friday and had it shipped it out the following Thur. $500. Can't beat that kind of service. Is it legal for a pilot to install the pump? Two fuel lines and a pair of wires. My guess is no. The wires and fuel lines are easy, the mounting screws can be a pain sometimes. But not too bad. Quote
