Huckster79 Posted May 23, 2023 Report Posted May 23, 2023 On my 2nd training flight we noticed this and headed home to get it checked out. The vacuum gauge needle was rocking back and forth rapidly- I could t post the video but you can see it in the screen shot… Any ideas? I’m going to have my mechanic take a look but I appreciate the community input to maybe head them in the right direction…
N201MKTurbo Posted May 23, 2023 Report Posted May 23, 2023 You should order your new vacuum pump now. You have one broken vane, the rest will follow shortly. 1
65MooneyPilot Posted May 23, 2023 Report Posted May 23, 2023 Did you just remove any instruments and change where the gauge is reading from? I just removed my last vacuum gyro indicator and mine is doing the same thing. It lost its snuber orifice used to dampen the indicator. I am going to have to figure how to put one back in the system. If not go with 201MKTURBO.
Huckster79 Posted May 24, 2023 Author Report Posted May 24, 2023 On 5/23/2023 at 9:07 AM, N201MKTurbo said: You should order your new vacuum pump now. You have one broken vane, the rest will follow shortly. On 5/23/2023 at 9:28 AM, 65MooneyPilot said: Did you just remove any instruments and change where the gauge is reading from? I just removed my last vacuum gyro indicator and mine is doing the same thing. It lost its snuber orifice used to dampen the indicator. I am going to have to figure how to put one back in the system. If not go with 201MKTURBO. it was the gauge itself. Swapped a spare in and reading was steady 4
Will.iam Posted May 24, 2023 Report Posted May 24, 2023 2 hours ago, Huckster79 said: it was the gauge itself. Swapped a spare in and reading was steady Wow that’s good to know. I’m sure that gauge was much cheaper than the pump itself.
Huckster79 Posted May 25, 2023 Author Report Posted May 25, 2023 2 hours ago, Will.iam said: Wow that’s good to know. I’m sure that gauge was much cheaper than the pump itself. Yessir! It cost me a “I wasn’t using it anyway, take it”.
0TreeLemur Posted May 25, 2023 Report Posted May 25, 2023 4 hours ago, Will.iam said: Wow that’s good to know. I’m sure that gauge was much cheaper than the pump itself. Those gauges are poorly made. I've come across several, and none of them agree with each other or a calibrated standard. Even new, they aren't very accurate, at least the one new one I tested. 2 hours ago, Huckster79 said: Yessir! It cost me a “I wasn’t using it anyway, take it”. Glad you didn't have to pay for it. 1
Huckster79 Posted May 29, 2023 Author Report Posted May 29, 2023 On 5/24/2023 at 10:31 PM, 0TreeLemur said: Those gauges are poorly made. I've come across several, and none of them agree with each other or a calibrated standard. Even new, they aren't very accurate, at least the one new one I tested. Glad you didn't have to pay for it. Kinda like everyone’s favorite beer is a free one
