I think someone posted a link within the last month for an M20J POH. Not sure what year it was for. Maybe you could search for it.
  On 12/15/2022 at 1:25 PM, ReconMax said:
GM MS--
Does anyone have a link to somewhere I can download a digital copy of the 1998 M20J POH?
Thanks for any help.
Expand
Look above in "Browse".  You might find it in the Downloads section.  If it isn't there maybe some kind soul will share it with you.  Good luck.
GM MS--
Expand
I can PM you a link to download from my former 1983 M20J which I scanned in.  I think the 1998 had at least these differences:
  • 24 Volt system
  • more electrically operated items, like cowl flaps
  • higher useful load so weight and balance will be different
  • most speeds should be the same
Definitely use at your own risk, as they are similar, but not identical planes.
-dan
Expand
The year is not always a definitive way to get the right documentation.  For example, here are two different AFM/POH manuals for a 1990 M20J:
1990   24-3144 thru 24-3153   POH-003200(A)
1990   24-3154 thru 24-3200   POH-003201
           24-3202 thru 24-3207   POH-003201
Best to look for the manual number from this list to be sure you have the right one:
https://www.mooney.com/wp-content/uploads/2020/12/Mooney-Technical-Publications.pdf
  • 1 year later...
Hello guys.
I live in Brazil and am in the process of negotiating a 1990 M20J and would love to start studying the POH in advance. According to the link sent by @Fly Boomer the correct document for me is the POH-003200(A).
Does anyone have a digital copy or a link for that specific POH?
Thank you all.
DC.
  On 7/19/2024 at 11:57 AM, DC_Brasil said:
Hello guys.
Thank you all.
DC.
Expand
All the M20J POH's are posted in the "Downloads" section of MooneySpace.  Click on the "Browse" button and you will see the dropdown.
