Rodeo John Posted September 22, 2022 Report Share Posted September 22, 2022 Does anyone know the part number for the bushings ? Quote Link to comment Share on other sites More sharing options...
Jpravi8tor Posted September 22, 2022 Report Share Posted September 22, 2022 are they located here? Quote Link to comment Share on other sites More sharing options...
Jpravi8tor Posted September 22, 2022 Report Share Posted September 22, 2022 sorry I see you have a 66 m20E Quote Link to comment Share on other sites More sharing options...
Jpravi8tor Posted September 22, 2022 Report Share Posted September 22, 2022 I see a 9140001-3 attach hinge this would be a @M20Doc question Quote Link to comment Share on other sites More sharing options...
carusoam Posted September 22, 2022 Report Share Posted September 22, 2022 Nice work jpr! MSer of the day award for that kind of help. Go MS! Quote Link to comment Share on other sites More sharing options...
Jpravi8tor Posted September 22, 2022 Report Share Posted September 22, 2022 If I had known the bearing part number or bearing dimensions that would have been worthy! I just replaced all the hardware in my elevator attach fittings and was surprised to find the bearings in great shape! Quote Link to comment Share on other sites More sharing options...
Rodeo John Posted September 22, 2022 Author Report Share Posted September 22, 2022 Page 116 -012 914001-003 is the same for 1966 M20E elevator hing Quote Link to comment Share on other sites More sharing options...
PT20J Posted September 23, 2022 Report Share Posted September 23, 2022 I believe that Mooney uses PN4A ball bearings for control surface hinges. Quote Link to comment Share on other sites More sharing options...
Guest Posted September 23, 2022 Report Share Posted September 23, 2022 12 hours ago, Rodeo John said: Page 116 -012 914001-003 is the same for 1966 M20E elevator hing The IPC a doesn’t break down the hinge fitting to the actual bearing part number. Contact Mooney for the bearing part number. Then with two small sockets and a C clamp you can change them. Quote Link to comment Share on other sites More sharing options...
Guest Posted September 23, 2022 Report Share Posted September 23, 2022 My wife found the part number, Skip was close. You need Heim Bearing PN3A also used in Cessna as S3895-1 or 0334128-3 Quote Link to comment Share on other sites More sharing options...
Jpravi8tor Posted September 23, 2022 Report Share Posted September 23, 2022 We need a library of sorts to catalogue data like this, I suspect it could be a forum category that once hard won information was found could be published, @irishpilot @Stetson20 @mooniac58 Quote Link to comment Share on other sites More sharing options...
Rodeo John Posted September 23, 2022 Author Report Share Posted September 23, 2022 Thanks to all I know somebody on this form would have all the right answers thanking everybody Quote Link to comment Share on other sites More sharing options...
