Oldguy Posted July 13, 2022 Report Posted July 13, 2022 Helping out a friend of mine who has a 1976 F. The baffles are just about falling apart and he is trying to decide on spending the AMUs to repair the existing ones or buy new. Does anyone have a source as to where baffles for a F model could be purchased? Airforms makes them for the J but not for the F. My recommendation would be an MSC or direct to the factory, if they are selling them. Anyone have any sources they know make them? TIA Quote
N201MKTurbo Posted July 13, 2022 Report Posted July 13, 2022 You might call Airforms, they told me they have PMA for more of the Mooney models than they advertise. They quit selling them because they don’t always fit just right. Not because they don’t make them right, but because the Mooneys are all a little different. If you can convince them you won’t be a PITA and that you might need to do a little rework, they may make you some. 2 Quote
Igor_U Posted July 13, 2022 Report Posted July 13, 2022 LASAR still has a number of baffles available but those are not always cheap. https://lasar.com/baffle-baffle-seals You'll need your parts catalog to get all the P/Ns you need. You might want to find a good sheet metal guy and make them. 1 Quote
M20F-1968 Posted July 26, 2022 Report Posted July 26, 2022 Better to make them. Use 0.040" thick aluminum. Use Machinist's Blue Dye and a sharp scriber. Trace out the parts. Cut, file or grind very slightly larger thn needed to permit hand filling with a file. Take your time, save alot of money and end up with a better product that fits your application. John Breda 5 Quote
Shadrach Posted July 26, 2022 Report Posted July 26, 2022 On 7/12/2022 at 10:01 PM, Oldguy said: Helping out a friend of mine who has a 1976 F. The baffles are just about falling apart and he is trying to decide on spending the AMUs to repair the existing ones or buy new. Does anyone have a source as to where baffles for a F model could be purchased? Airforms makes them for the J but not for the F. My recommendation would be an MSC or direct to the factory, if they are selling them. Anyone have any sources they know make them? TIA Just to be clear, you are referring to the baffles (sheet metal) and not the baffle seals (silicon rubber)? Quote
Oldguy Posted July 31, 2022 Author Report Posted July 31, 2022 On 7/26/2022 at 2:38 PM, Shadrach said: Just to be clear, you are referring to the baffles (sheet metal) and not the baffle seals (silicon rubber)? Correct, sir. And he has found someone to rebuild/make a set for him. In Longview... 1 Quote
KSMooniac Posted July 31, 2022 Report Posted July 31, 2022 Correct, sir. And he has found someone to rebuild/make a set for him. In Longview...There is some sheet metal magic that's been known to happen in Longview.Sent from my LM-V450 using Tapatalk Quote
davesly Posted May 3, 2023 Report Posted May 3, 2023 I sure could use some help finding someone to make M20F baffles as well. Please let me know if anyone has a contact who could help me. Thanks! Quote
M20F-1968 Posted May 11, 2023 Report Posted May 11, 2023 If you are detail-oriented, good with hand tools, and have access to an A&P that has a brake, sheer, sheet metal roller and will let you use it, or he will do it for you, you are likely better off to make them yourself. The bulk of the work is measuring, carefully fitting with Dremel tool/files. Use the old baffles as a template and lay the parts out with machinist's dye and a scriber. Riveting can be tricky if you have never done it. A pneumatic rivet squeezer makes life much easier. John Breda 1 Quote
MooneyMayhem Posted May 11, 2023 Report Posted May 11, 2023 On 5/3/2023 at 11:49 AM, davesly said: I sure could use some help finding someone to make M20F baffles as well. Please let me know if anyone has a contact who could help me. Thanks! I run my own metal fabrication shop and just finished a set of aluminum baffles for a C210. Some of the factory parts were fine but a half dozen side baffles were cracked and/or falling apart and needed replaced. I'm not familiar with the Mooney baffling but if you send me a pic, I may be able to help. 3 Quote
Fly Boomer Posted May 11, 2023 Report Posted May 11, 2023 3 hours ago, MooneyMayhem said: I run my own metal fabrication shop and just finished a set of aluminum baffles for a C210. Some of the factory parts were fine but a half dozen side baffles were cracked and/or falling apart and needed replaced. I'm not familiar with the Mooney baffling but if you send me a pic, I may be able to help. That is a heck of an offer! I'll bet @davesly isn't the only one that could use some new baffles. Quote
davesly Posted May 14, 2023 Report Posted May 14, 2023 Thanks for the offer. Unfortunately, I don't have any baffles at all to use as a template. I purchased a 1969 Mooney M20F without an engine. All I have to go by are the picture of the baffle system in the parts guide. Lasar did get back to me and said that they had the front Right and both rear-side baffles in stock. The two front-side baffles are in their system but are out of stock. They don't have the front left, or either of the rear baffles in their system. On 5/11/2023 at 9:09 AM, MooneyMayhem said: I run my own metal fabrication shop and just finished a set of aluminum baffles for a C210. Some of the factory parts were fine but a half dozen side baffles were cracked and/or falling apart and needed replaced. I'm not familiar with the Mooney baffling but if you send me a pic, I may be able to help. Quote
Sabremech Posted May 19, 2023 Report Posted May 19, 2023 On 5/14/2023 at 10:46 AM, davesly said: Thanks for the offer. Unfortunately, I don't have any baffles at all to use as a template. I purchased a 1969 Mooney M20F without an engine. All I have to go by are the picture of the baffle system in the parts guide. Lasar did get back to me and said that they had the front Right and both rear-side baffles in stock. The two front-side baffles are in their system but are out of stock. They don't have the front left, or either of the rear baffles in their system. I have F model baffling except for the front of the cylinders that is excess for my needs. It’s available if you need a good start. Appears to be in fairly decent shape. Thanks, David 1 Quote
davesly Posted May 19, 2023 Report Posted May 19, 2023 11 hours ago, Sabremech said: I have F model baffling except for the front of the cylinders that is excess for my needs. It’s available if you need a good start. Appears to be in fairly decent shape. Thanks, David Thanks! I just sent you a PM. Quote
Mcstealth Posted June 6, 2023 Report Posted June 6, 2023 On 5/11/2023 at 9:09 AM, MooneyMayhem said: I run my own metal fabrication shop and just finished a set of aluminum baffles for a C210. Some of the factory parts were fine but a half dozen side baffles were cracked and/or falling apart and needed replaced. I'm not familiar with the Mooney baffling but if you send me a pic, I may be able to help. @MooneyMayhem Did anything become of this project? Quote
MooneyMayhem Posted June 9, 2023 Report Posted June 9, 2023 On 6/6/2023 at 1:31 PM, Mcstealth said: @MooneyMayhem Did anything become of this project? The 210? It's back up and flying. As far as OP, I think he's taken care of Quote
Mcstealth Posted June 9, 2023 Report Posted June 9, 2023 The metal shop guy making new baffles? Quote
davesly Posted June 11, 2023 Report Posted June 11, 2023 I will post pics and dimensions of the rear and sides. Working with Denis (VH-KWA) on getting scans of the front two baffles. Quote
Mcstealth Posted June 11, 2023 Report Posted June 11, 2023 1 hour ago, davesly said: I will post pics and dimensions of the rear and sides. Working with Denis (VH-KWA) on getting scans of the front two baffles. There you are. Good luck. Quote
TaildraggerPilot Posted March 5, 2024 Report Posted March 5, 2024 What’s the latest on this? Is anyone making M20F baffles now? I have a doghouse on my 67 E, but it was built during the transition period and has the proper reinforced upper cowling. I would love to switch to an open baffle setup. Quote
