Shadrach Posted June 3, 2022 Report Posted June 3, 2022 That’s an oldie but a goodie. I think that’s a clear case of the down lock either failing for the J bar not being fully seated. The full video showcases some excellent teamwork. About 10 men divided between the nose, tail and wings pick it up and extend the gear. 1 Quote
EricJ Posted June 3, 2022 Report Posted June 3, 2022 1 hour ago, Shadrach said: That’s an oldie but a goodie. I think that’s a clear case of the down lock either failing for the J bar not being fully seated. The full video showcases some excellent teamwork. About 10 men divided between the nose, tail and wings pick it up and extend the gear. Yup, here's the whole thing. Somewhere I saw that it was likely due to the misrigging. You can see the nose gear gets bounced hard a couple times and then folds up first, pulling the mains up with it. 1 Quote
Shadrach Posted June 3, 2022 Report Posted June 3, 2022 1 hour ago, EricJ said: Yup, here's the whole thing. Somewhere I saw that it was likely due to the misrigging. You can see the nose gear gets bounced hard a couple times and then folds up first, pulling the mains up with it. Seems odd that it would be operable after such an event. Something would have to bend/break. Quote
EricJ Posted June 4, 2022 Report Posted June 4, 2022 8 hours ago, Shadrach said: Seems odd that it would be operable after such an event. Something would have to bend/break. You can see that they had to pull on the mains to get them to lock. They didn't lock just from the Johnson bar, apparently. I suspect the rods were bent a bit. 1 Quote
kerry Posted June 6, 2022 Report Posted June 6, 2022 Now all they need is for the 10 men to bend the propeller back to it normal shape and the Mooney can fly away. 3 Quote
