Since cylinders are back-ordered for six weeks, I offered an old cylinder off my a/c to a fellow mooney owner.  It is P/N LW-12427.  My engine is a wide deck O-360, his is a narrow deck.  Will this cylinder work on his engine?
Thanks,
Fred
  On 3/23/2022 at 10:36 PM, Utah20Gflyer said:
How do you know if your engine is a narrow or wide?  Is there an easy way to determine it?  Thanks
Expand
The narrow deck has the plates on the cylinder base and the internal wrenching nuts.  The wide deck has no plates on the base of the cylinders and regular hex nuts.
Mark
Do not rely on the engine serial number. Look for the plates and the internal wrenching nuts which are unique to narrow deck cylinders.
I know about an engine that has a wide deck serial number, but is needs narrow deck cylinders.
