Gary Bymers Posted February 8, 2022 Report Posted February 8, 2022 More parts. I owned and M20C for 34 years, owned an M20A for 15 years (I had the C & A at the same time) and now have a 201 J. When I recently upgraded to a J, realized I have way too many spares that I don't need. Let me know what you are looking for, I may have it. Just call or text with questions - thanks Gary 6O8 334 OO51
corn_flake Posted February 8, 2022 Report Posted February 8, 2022 You weren't kidding when you say you got a few spare parts!! Are those wood prop?! I didn't know Mooney came with wood prop! What was the year?
Darrell Donnelly Posted December 16, 2024 Report Posted December 16, 2024 Hello, I am looking for firewall forward for a 1965 Mooney super 21. I have all the cowlings but need engine mount and so on. I would be interested in an engine if you have one cheers Darrell Donnelly donnel@tbaytel.net 800-563-5423
00-Negative Posted December 16, 2024 Report Posted December 16, 2024 12 hours ago, Darrell Donnelly said: Hello, I am looking for firewall forward for a 1965 Mooney super 21. I have all the cowlings but need engine mount and so on. I would be interested in an engine if you have one cheers Darrell Donnelly donnel@tbaytel.net 800-563-5423 @Gary Bymers
grandwhazoo Posted June 1 Report Posted June 1 looking for the step servo. mod BI-706, pn 4059-1 or perhaps just the parts to fix the one i have. The rubber skirt on the plunger is torn and if there is an apron to prevent total vacuum leak, would need that as well ( i believe there are a series of these things, if you have one with the same ID, could probably use the parts to fix mine, which leaks like a seive)
Samir13k Posted June 1 Report Posted June 1 Would you happen to have any wheels (nose or main) in there by any chance? Looking for my M20G, should be the same as C-K with serials 670001. Thank you!
TheAv8r Posted June 1 Report Posted June 1 8 hours ago, grandwhazoo said: looking for the step servo. mod BI-706, pn 4059-1 or perhaps just the parts to fix the one i have. The rubber skirt on the plunger is torn and if there is an apron to prevent total vacuum leak, would need that as well ( i believe there are a series of these things, if you have one with the same ID, could probably use the parts to fix mine, which leaks like a seive) I have one that's in pretty good shape and it worked fine in my plane before we replaced it with the electric step, but I do think there is a tear in the boot. It wasn't enough to cause it not to work, but it's there. Let me know if you're interested.
