I have a G3X Touch, GTN 650Xi (Nav 1) and a GNC 255 (Nav 2). I always use the G3X with the GTN (GPS1). But sometimes the G3X powers up with VLOC2 selected. Has anyone \else seen this and has anyone found a way to make the G3X remember the last used nav source?
Skip
  • 2 weeks later...
I received the following response from Garmin support:
Unfortunately, we don’t know of a way to control that. I was not able to get an answer from the engineering department as to why it is designed that way.
Skip
I'm guessing the power supply in the number 2 radio just has a larger capacitor which keeps the radio alive longer on shutdown than the number 1 and the G3X switches when it loses a valid signal from number 1.  You might want to try shutting down number 2 first on shutdown for a few times to see if that stops the switching.
I did some experimenting today. Per the STC, the G3X is powered directly off the master switch and the GTN (GPS/VLOC 1) and GNC (VLOC2) are powered from the avionics switch.
I landed with the G3X nav source selected to GPS1. I turned off the avionics switch killing the radios. G3X still shows GPS1. I turned off the master shutting down the G3X. I refueled the airplane and turned on the master but not the avionics switch. The G3X boots up with VLOC2 selected.
EDIT: I should point out once again that this seems random. The last few times I did this it stayed on GPS1.
Skip
