bmcconnaha Posted November 26, 2021 Report Posted November 26, 2021 Ordering tubes for the mains today. I have a 1990 J with hub cabs. I have heard sometimes the 90 degree stem will not work with the hubcaps. I saw a thread about the 70 degree stems, but I couldn't tell if that will work on my J. What tubes are you using on your mains? Thanks! Quote
MisfitSELF Posted November 26, 2021 Report Posted November 26, 2021 I just replace both my main tires and tubes. I have a 1984 M20J with hub caps. Of course I have to take off the caps to service them. My previous right tube leaked slowly and I ended up having to service it every 2-3 weeks. Previous owner said something about it being a "cheap" tube. Here's the ones I got and I haven't had to service them since June! https://www.aircraftspruce.com/catalog/lgpages/michAviator2.php Quote
LANCECASPER Posted November 26, 2021 Report Posted November 26, 2021 6 minutes ago, MisfitSELF said: I just replace both my main tires and tubes. I have a 1984 M20J with hub caps. Of course I have to take off the caps to service them. My previous right tube leaked slowly and I ended up having to service it every 2-3 weeks. Previous owner said something about it being a "cheap" tube. Here's the ones I got and I haven't had to service them since June! https://www.aircraftspruce.com/catalog/lgpages/michAviator2.php Good choice! Get any tubes you want as long as they are Michelin Airstops . . 2 Quote
bmcconnaha Posted November 26, 2021 Author Report Posted November 26, 2021 43 minutes ago, MisfitSELF said: I just replace both my main tires and tubes. I have a 1984 M20J with hub caps. Of course I have to take off the caps to service them. My previous right tube leaked slowly and I ended up having to service it every 2-3 weeks. Previous owner said something about it being a "cheap" tube. Here's the ones I got and I haven't had to service them since June! https://www.aircraftspruce.com/catalog/lgpages/michAviator2.php I've had good luck with Goodyear tubes also. Are the ones you ordered straight valve? Quote
StevenL757 Posted November 26, 2021 Report Posted November 26, 2021 1 hour ago, bmcconnaha said: I've had good luck with Goodyear tubes also. Are the ones you ordered straight valve? Michelin Airstops. Worth every penny. Quote
ZuluZulu Posted November 28, 2021 Report Posted November 28, 2021 On 11/26/2021 at 10:40 AM, LANCECASPER said: Good choice! Get any tubes you want as long as they are Michelin Airstops . . I also recently switched to Airstops and have been very satisfied. Quote
MisfitSELF Posted November 29, 2021 Report Posted November 29, 2021 On 11/26/2021 at 11:19 AM, bmcconnaha said: I've had good luck with Goodyear tubes also. Are the ones you ordered straight valve? Yes Quote
bmcconnaha Posted November 29, 2021 Author Report Posted November 29, 2021 9 hours ago, MisfitSELF said: Yes Thank you Quote
