Mcxmike Posted November 12, 2011 Report Posted November 12, 2011 Any suggestions as to where to find fuel cap gaskets for an 85 M20. Would Lake Aero be the place for find them? Thanks... Quote
kortopates Posted November 12, 2011 Report Posted November 12, 2011 I assume you're referring to the fuel cap o-rings. Large one on the outside and small one inside. Both are available from Spruce Aircraft or your local MSC. 85 M20 what? Check your IPC, but for either J or K, you should find: MS 29513-338 large fuel cap o-rings MS 29513-010 small fuel cap o-rings Quote
flyboy0681 Posted November 12, 2011 Report Posted November 12, 2011 I recently replaced all of mine. The large ones were a cinch, the small internal ones not so easy. Quote
Clarence Posted November 20, 2011 Report Posted November 20, 2011 Check out the Mooney S/B on fuel cap "O" ring: http://www.mooney.com/images/pdfs/sb-pdf/sbm20-229a.pdf Clarence Quote
