irishpilot Posted January 20, 2021 Report Posted January 20, 2021 On 1/17/2021 at 4:05 PM, kortopates said: The Bravo seems to be the most under valued airframe in the fleet for some time now. It doesn't make sense IMO. Sent from my iPhone using Tapatalk I think people shy away from the turbo and high fuel consumption. It's easy to compare an Encore or 252 to a Bravo and balk at 18-19 gph cruise. Again, its all about what you want and are willing to pay for. Both 252s and Bravos are great airplanes. I went with a Bravo because when running the TAS and fuel burn, for long distance travel it isn't a huge difference. I've flown and owned both NA and turbo aircraft. For long distance travel, I'd take a turbo any day. I typically fly in the high teens and low FLs and usually hear, "cleared direct destination" 500+ miles out. I am very happy with my Bravo. 4
J Bird Posted January 22, 2021 Report Posted January 22, 2021 I came across this aircraft back in June/July 2020 and from what I was told it was sold!?
jlunseth Posted January 25, 2021 Report Posted January 25, 2021 On 1/18/2021 at 10:14 PM, carusoam said: I got to pick up the top of a raw carbon fiber O cowl... at the last KOSH event... while speaking with Kevin Kramer... Incredibly light... For each pound up front, a similar lead weight comes out of the back... proper WnB calcs are important... We would be double dipping in UL benefits! -a- Turbos are generally nose heavy and the CG with two full sized adults in the front seats and no luggage, is at or over the limit. Even if a counterweight does not come out, it would be a big help in my aircraft. I am hearing 70-80 lbs. lighter, which is hard to believe, but it came from a good source. 1
aviatoreb Posted January 25, 2021 Report Posted January 25, 2021 15 minutes ago, jlunseth said: Turbos are generally nose heavy and the CG with two full sized adults in the front seats and no luggage, is at or over the limit. Even if a counterweight does not come out, it would be a big help in my aircraft. I am hearing 70-80 lbs. lighter, which is hard to believe, but it came from a good source. Don't forget that the M20K standard fuel is quite a bit higher than M20J standard fuel. So that is part of why the lower full fuel useful load. Of course the other part is the engine.
jlunseth Posted January 25, 2021 Report Posted January 25, 2021 More UL would be nice, but with a CG right at the forward limit it would be nicer to have a lighter nose.
