xcrmckenna Posted January 2, 2021 Report Posted January 2, 2021 Where is your Gad13 installed? I’m thinking of mounting it behind the panel next to my encoder on a bracket. Sent from my iPhone using Tapatalk Quote
jamesm Posted January 2, 2021 Report Posted January 2, 2021 (edited) I am not sure which altitude encoder you have. I have the ACK 31 altitude encoder since there some short stringers running along fuselage. I put an aluminum square tube side of the fuselage to clear the stringer(s) then placed an aluminum plate with nut plates for the ACK 31 altitude encoder and the GAD 13 to mount on. I used the 2 screw holes on the side of the fuselage previously used for the wing lever rate gyro just off and above the pilot's knee. The previous installer had mounted it on the right side but I wanted to keep my static lines fairly short. James '67C Edited January 2, 2021 by jamesm 1 Quote
Baker Avionics Posted January 8, 2021 Report Posted January 8, 2021 We install them usually close to the GAD29B for ease of installation and wiring purposes. If that isn't as easily accessible, then where you are thinking should be fine. 2 Quote
xcrmckenna Posted January 9, 2021 Author Report Posted January 9, 2021 We install them usually close to the GAD29B for ease of installation and wiring purposes. If that isn't as easily accessible, then where you are thinking should be fine. The GAD29b will be installed later this year and it will probably go in the avionics bay in the tail. Sent from my iPhone using Tapatalk Quote
