flyer7324 Posted December 23, 2020 Report Posted December 23, 2020 62 C model. Purchasing a factory reman from Lycoming and switching from generator to alternator. Probably going to go with Plane Power/Hartzell but need to know whether Plane Power is a Prestolite or Chrysler style of alternator for the engine order. Any help with this would be appreciated. Thanks, Mitch Berger
RLCarter Posted December 23, 2020 Report Posted December 23, 2020 If it’s for the mounts, my PlanePower conversion came with the mounts
Igor_U Posted December 24, 2020 Report Posted December 24, 2020 1 hour ago, flyer7324 said: 62 C model. Purchasing a factory reman from Lycoming and switching from generator to alternator. Probably going to go with Plane Power/Hartzell but need to know whether Plane Power is a Prestolite or Chrysler style of alternator for the engine order. Any help with this would be appreciated. Thanks, Mitch Berger Mitch, I believe difference is in the pulley but not sure which is which. When shopping for OH, Air Power asked the same question. I am also planning to go with Plane Power. I want to rewire installation and install 70 amp breaker to take advantage of full capacity as well as to clean some of the old wiring. I would be interested to hear what you find and your experience with conversion. Thanks
chriscalandro Posted December 24, 2020 Report Posted December 24, 2020 14 hours ago, Igor_U said: Mitch, I believe difference is in the pulley but not sure which is which. When shopping for OH, Air Power asked the same question. I am also planning to go with Plane Power. I want to rewire installation and install 70 amp breaker to take advantage of full capacity as well as to clean some of the old wiring. I would be interested to hear what you find and your experience with conversion. Thanks Most shunts are 50a so you’re going to want one of those too. you shouldn’t be anywhere near 50a so I don’t understand why you would want to do this.
jamesm Posted December 24, 2020 Report Posted December 24, 2020 If I remember correctly the prestolite vs Chrysler has do with polarity Of the voltage regulator of the field circuit on the alternator. Don't quote Me on this I believe most on Mooney's are type 'B' let double check First. Hope this helps, James '67C
