P-51 Overlay with long body please
Seth
Here is the P-51 and M20 C/D/E overlay picture.
Can someone do the same with a M20M/R or M20U/V?
That way the snout and tail will be in better proportion. The factory should have run this as an add years ago.
Once don’t I’d love the file so I can print a high quality image of it for display somewhere.
  • Like 5
Link to comment
Share on other sites
1 hour ago, Schllc said:
Amazing, 15% difference in size but four times gross weight. And 5x hp
I flew one of these and without weapons armor and drop tanks the climb rate is 7k minute!!
To heck with a turbine put a RR on a Mooney!!!
there was nearly an RR option for the Mooney....  it was in development around 2007.
It looked really good for about a year.... just out of phase with the economy at the time...
That was an RR turbine...  :)
Link to comment
Right - I remember that. It was a special slightly smaller RR turbine engine that I don't think it ended up completing toward certification either since there were no airframes promising to use it in the end.
Link to comment
5 hours ago, bfreelove said:
2083610207_ScreenShot2020-09-13at20_53_58.thumb.png.7224d58a999be206e7bed92d47198bcc.png
That looks amazing. The Mooney wing is 36 feet 6 inches and the P-51 37 feet. Tbe P-51 is longer by a few feet and the long body just overlays in the pic a bit better.
Thank you!
Question, this looks like P-51H wing and not a P-51D wing, can you overlay on a P-51D?
Thanks!
-Seth
Link to comment
16 hours ago, M20Doc said:
I’m sure that the only connection between a Mooney and a Mustang is the aluminum.  A Navion has a stronger connection.
Clarence-
actually the leading edge was made by the press purchased from North American. The P-51B/Press for the leading edge was in the factory back in the 1980’s as per Bob Kromer. The wing if you look is a slightly scaled down P-51 shape and the leading edge was the P-51 leading edge.
We learned about this during a Mooney Summit session 4-5 years ago.
This is why for years I felt Mooney could have somehow capitalized on that.
-Seth
Link to comment
An interesting bit of history for sure.  I’ll share mine.  I bought a rivet squeezer when building my RV4, alleged to have been used by Goodyear during WW2.  So my RV4 is really a Corsair!
Link to comment
