Badmoonraising Posted June 28, 2020 Report Posted June 28, 2020 I am going through annual hell. We (AME) found missing rivets at the wing root just ahead of the drain. There appears to be a small burn make there and my AME (very experienced) has seen this before. He thinks my airplane suffered a lightning ground strike. All else is well. I will jump ahead here, I have stripped the sealant from the tank. This is one of the must unpleasant tasks I have ever had to do. We have found corrosion to the T shaped extrusion of the rib. This would have never been visible had we not removed rivets allowing us to pull the skin down. I am fortunate to have a very experienced aviation sheet metal man. I'm assisting him. He feels this is repairable. Does anyone have a part number? Can I get this from Mooney? 1 Quote
EricJ Posted June 28, 2020 Report Posted June 28, 2020 5 minutes ago, Badmoonraising said: I am going through annual hell. We (AME) found missing rivets at the wing root just ahead of the drain. There appears to be a small burn make there and my AME (very experienced) has seen this before. He thinks my airplane suffered a lightning ground strike. All else is well. I will jump ahead here, I have stripped the sealant from the tank. This is one of the must unpleasant tasks I have ever had to do. We have found corrosion to the T shaped extrusion of the rib. This would have never been visible had we not removed rivets allowing us to pull the skin down. I am fortunate to have a very experienced aviation sheet metal man. I'm assisting him. He feels this is repairable. Does anyone have a part number? Can I get this from Mooney? Not sure exactly what part you're looking for, but get a copy of the Illustrated Parts Catalog (IPC) for your airplane and you should be able to find a part number reasonably quickly. Quote
Jim Peace Posted June 28, 2020 Report Posted June 28, 2020 7 minutes ago, Badmoonraising said: I am going through annual hell. We (AME) found missing rivets at the wing root just ahead of the drain. There appears to be a small burn make there and my AME (very experienced) has seen this before. He thinks my airplane suffered a lightning ground strike. All else is well. I will jump ahead here, I have stripped the sealant from the tank. This is one of the must unpleasant tasks I have ever had to do. We have found corrosion to the T shaped extrusion of the rib. This would have never been visible had we not removed rivets allowing us to pull the skin down. I am fortunate to have a very experienced aviation sheet metal man. I'm assisting him. He feels this is repairable. Does anyone have a part number? Can I get this from Mooney? picture of the area with missing rivets? 1 Quote
ArtVandelay Posted June 28, 2020 Report Posted June 28, 2020 If you expect a specific part number, then I suggest more information is required: model number, serial number, picture of part and its location. Quote
Badmoonraising Posted June 28, 2020 Author Report Posted June 28, 2020 Thanks guys. I suppose that's true. Here's photo. The extrusion is the inverted T of the most inboard rib. The bottom extrusion. Quote
Guest Posted June 28, 2020 Report Posted June 28, 2020 (edited) From the IPC, the rib isn’t broken down to the individual parts. You’ll need to provide the serial number of your plane to get the correct part number from the correct IPC. With the correct rib part number you can ask Mooney for a further break down of the rib. Clarence Edited June 28, 2020 by M20Doc Quote
SheryLoewen Posted June 29, 2020 Report Posted June 29, 2020 Item #3 210026-022 Cap lower Loewens Mooney salvage may have a used one with rivet holes . Paul Loewen 1 Quote
carusoam Posted June 29, 2020 Report Posted June 29, 2020 Ouch... Is there a matching mark on the ground where that was parked? The pavement, may not have fared much better... But, this would confirm what you are seeing..... Electricity is a very powerful force. Often, the damage is very surface related... there may also be an entrance wound.... Expect that the tallest part of the plane may have got hit... the lowest part with ‘best’ contact with the ground looks like the exit.... Got any security cameras nearby? To review the tape? PP thinking out loud... not a lightning bug... Best regards, -a- Quote
SheryLoewen Posted June 30, 2020 Report Posted June 30, 2020 I found the Rib with extrusion see picture Call me Paul Loewen 707 263-0462 1 Quote
carusoam Posted July 1, 2020 Report Posted July 1, 2020 @Badmoonraising your rib may have just flown in... See Paul’s post and pic above... -a- Quote
