V1VRV2 Posted June 23, 2020 Report Posted June 23, 2020 (edited) I I did a search and can’t seem to find a single bit of info on this very rare model... the 1992 model M20J 201 MSE Limited. The only info I could find was that it had “special equipment”. Could someone shed some light on this model and the differences between it and the MSE which was also offered in 1992. Mooney is a hornets nest of models and numbers and letters!!!! Trying to make sense of it all makes my head hurt! Edited June 23, 2020 by V1VRV2 Quote
elimansour Posted June 23, 2020 Report Posted June 23, 2020 Check out the information on this site http://www.mooneyevents.com/chrono.htm and download the spreadsheet for the detailed history. Apparently, the Limited meant that there was a paint change. 1 Quote
V1VRV2 Posted June 23, 2020 Author Report Posted June 23, 2020 Thanks for that link. I have been using that as a reference. It doesn’t mention a paint change. I found an advertisement from flying mag that mentions specifically “ special equipment”. Thanks for your help! Quote
MIm20c Posted June 23, 2020 Report Posted June 23, 2020 I’d check out n40bk that Neal is selling. Looks pretty nice. 3 Quote
Mcstealth Posted June 23, 2020 Report Posted June 23, 2020 4 hours ago, V1VRV2 said: I I did a search and can’t seem to find a single bit of info on this very rare model... the 1992 model M20J 201 MSE Limited. The only info I could find was that it had “special equipment”. Could someone shed some light on this model and the differences between it and the MSE which was also offered in 1992. Mooney is a hornets nest of models and numbers and letters!!!! Trying to make sense of it all makes my head hurt! @jgarrison Maybe Mr J has some insight? 1 Quote
carusoam Posted June 24, 2020 Report Posted June 24, 2020 Realistically... MSE is Mooney Special Edition... Which included many things like a high level of avionics, and leather interior niceties.... But once the plane is 20+ years old... all the avionics and leather bits related to the name MSE... might be disappointing... A fancy BK suite of electronics isn’t much to get excited about after 25years... WAAS has arrived, as has wide screen color PFDs... The opposite of the MSE, was the AT and Mooney Eagle... Again after a few years, they may have been updated to forever-plane status... So be on the look-out for a rare Mooney F-P.... Best regards, -a- 1 Quote
V1VRV2 Posted June 24, 2020 Author Report Posted June 24, 2020 (edited) I have gathered bits and pieces from articles and advertisements. I believe the MSE Limited was a stripped down MSE aimed at budget minded buyers. Think stealing Cessna and Piper customers. Here is one of the ads I’ve seen. It says “The Limited comes in at a price lower than the already affordable MSE” Edited June 24, 2020 by V1VRV2 1 Quote
elimansour Posted June 24, 2020 Report Posted June 24, 2020 I just remembered I have a copy of Those Remarkable Mooneys - so was able to find the following: 2 Quote
carusoam Posted June 24, 2020 Report Posted June 24, 2020 In 94, The Ovation MSE had everything but O2, AC, and FIKI.... The AP was a KAP150... The only thing better was one with a FD in it... A few things could be added on... altitude Pre-select... All digital instruments, with analog displays... All digital radios, with gas discharge displays... A new Mooney for 160amu sounds really good... even with an empty panel... The things left off the options list require some thinking...price and weight are significant... all can be added at a later time... Best regards, -a- 1 Quote
elimansour Posted June 24, 2020 Report Posted June 24, 2020 Just now, carusoam said: A new Mooney for 160amu sounds really good Doesn't it? According to a CPI inflation calculator (https://www.in2013dollars.com/us/inflation/1994?amount=1) $1 in 1994 is approx. $1.74 in 2020. Using that math, a new Mooney in 2020 should be $278K with an empty panel...Hmmm....is it all due to higher volume in '94? 1 Quote
jgarrison Posted June 28, 2020 Report Posted June 28, 2020 On 6/23/2020 at 5:04 PM, Mcstealth said: @jgarrison Maybe Mr J has some insight? The big difference between the MSE and MSE Limited was a KAP-100 Autopilot in place of the KAP-150 and no HSI. There were other minor differences. Like the lower side carpets were replaced with royalite plastic and if I remember correctly, there were no sun visors. No middle arm rest. Cheaper carpet material and seat material. Mechanical cowl flaps vs. electric if I remember right. The reference to the inflation adjuster above. The big difference(s) between 1994 and now are labor rates, the cost of non-factory produced components (which also include much larger liability premiums) and the cost of liability premiums for the factory. Since the Mooney airframe takes 5000+ hours to hand build, you have to figure that the cost of labor is probably three times now what is was back in 1994. Cost of an engine and accessories, probably 3-4 times. And liability insurance premiums maybe 5-10 times what they were then and not spread over as many units. I just got a 1989 M20J that I am hoping to turn into a basically 'new' plane. I'm guessing if it were actually new, it would probably have to sell for between 600 and 700K for it to break even. I am going to try to stay under $225K for it, which is very high for a J, but in relation to new-new, it will be a bargain. 2 3 Quote
bmcconnaha Posted June 29, 2020 Report Posted June 29, 2020 On 6/23/2020 at 10:53 AM, MIm20c said: I’d check out n40bk that Neal is selling. Looks pretty nice. how would i go about getting some info on that bird? Quote
KLRDMD Posted June 30, 2020 Report Posted June 30, 2020 4 hours ago, bmcconnaha said: how would i go about getting some info on that bird? https://www.controller.com/listings/aircraft/for-sale/192266609/1994-mooney-m20j-mse 2 Quote
bmcconnaha Posted June 30, 2020 Report Posted June 30, 2020 1 minute ago, KLRDMD said: https://www.controller.com/listings/aircraft/for-sale/192266609/1994-mooney-m20j-mse thanks! Quote
87-205SE Posted July 1, 2020 Report Posted July 1, 2020 Just bought a 87 205. HSI. KFD 150 Center arm rest....big deal 1300 TT with new prop and Premier overhaul. Paid 140 and ecstatic. Basically a new faster (a little) J like new airplane. Probably my last airplane unless I hit the lottery and I couldn't be happier. Electric cowl flaps and ram air. You can probably steal it from my widow. Enjoy Quote
Mooney217RN Posted July 1, 2020 Report Posted July 1, 2020 18 minutes ago, 87-205SE said: Just bought a 87 205. HSI. KFD 150 Center arm rest....big deal 1300 TT with new prop and Premier overhaul. Paid 140 and ecstatic. Basically a new faster (a little) J like new airplane. Probably my last airplane unless I hit the lottery and I couldn't be happier. Electric cowl flaps and ram air. You can probably steal it from my widow. Enjoy Congrats fellow Mooniac. It won't be your last M20 Fast Mover. You'll step up to another one day... Quote
ArtVandelay Posted July 1, 2020 Report Posted July 1, 2020 Just bought a 87 205. HSI. KFD 150 Center arm rest....big deal 1300 TT with new prop and Premier overhaul. Paid 140 and ecstatic. Basically a new faster (a little) J like new airplane. Probably my last airplane unless I hit the lottery and I couldn't be happier. Electric cowl flaps and ram air. You can probably steal it from my widow. Enjoy 33 years old and only 1300 hours? Quote
87-205SE Posted July 23, 2020 Report Posted July 23, 2020 Original owner probably an engineer. Second owner and A&P. Airplane is like new. Seattle to Detroit 10 hrs flight time. 170 TAS I can send you a pic. Prox 70% power at 7000 burning 11.5. My first 83 201 was great. This 205 is fabulous. 1 Quote
