I think I solved my issue....pending test flight. I replaces the probe with new unit...still 0 Fuel FJpi edm fuel flow has 3 wire molex connector to probe. With master on per Tim at JPI  you should get 12v ish on red to black and 4-5 V on white to black with probe disconnected. I was getting 0 volts on white to black. I took off the P4 labled dinn connector and reseated it .  I now shows 4.8V on white wire 12V on red and allso shows FF during priming.
