At the 1st annual inspection the only surprise was after the elevator trim link #740170-001 and bushing #914017-000 were replaced, when the trim indicator is set in the takeoff position, it produces a significant nose down position.  For takeoff now, instead of the indicator and takeoff mark being align, I must set the indicator entirely above the takeoff mark. Mechanic said nothing else was moved, turned, adjusted, etc.  I can have the indicator adjusted, but has anyone else experienced this after having the trim link replaced?
You need the correct travel board to re set the trim system.
