DeltaZulu Posted October 11, 2019 Report Share Posted October 11, 2019 Hi there(: a m20c with IO-360-A3B6D How much will be An overhaul? also I’m a bit scared of the dual mags. is it possible to install 2 separate mags? Quote Link to comment Share on other sites More sharing options...
Jerry 5TJ Posted October 11, 2019 Report Share Posted October 11, 2019 You have an M20C with an IO-360-A3B6D? A curious bird. The STC is in the plane’s logs? For Overhaul basic prices — Airpower is a good place to start looking. Around $41,000 if your core is good. 1 Quote Link to comment Share on other sites More sharing options...
Greg Ellis Posted October 11, 2019 Report Share Posted October 11, 2019 Very curious. Not only to be an IO-360 and not just an O-360 but to tack on the mags as well....interesting. 1 Quote Link to comment Share on other sites More sharing options...
Shiny moose Posted October 11, 2019 Report Share Posted October 11, 2019 You own this or looking to buy it? Paperwork Paperwork paperwork !!! I would say it another 50 tImes if I wasnt so tired 1 Quote Link to comment Share on other sites More sharing options...
Yetti Posted October 12, 2019 Report Share Posted October 12, 2019 Check the engine plate on the front right of the engine 1 Quote Link to comment Share on other sites More sharing options...
Hank Posted October 12, 2019 Report Share Posted October 12, 2019 M20-Cs were built with a carbureted O-360A1D engine of 180 hp with two magnetos. The IO-360 A3B6D is a fuel injected, dual-magneto 200 hp engine originally used in M20-Js. A few have been put into other models, but the engine STC is required, along with the more expensive engine, different cowling, different spinner and likely different engine mounts and propellor--not something done on a whim. Make sure the airplane logs clearly explain the work done, and that the STCs are present and logged to the aircraft serial number. Even then, overhaul will be much higher cost than an O-360, even without the frequent conversion: dual magneto to two magnetos. Safety Note: dual magnetos can cause complete engine failure if one side fails the wrong way. Experience Note: I have lost my left (cranking) magneto in flight, away from home, and was able to easily land without undue concern. This may or may not be possible when one side of a dual magneto fails, depending on the failure mode. 1 Quote Link to comment Share on other sites More sharing options...
DeltaZulu Posted October 12, 2019 Author Report Share Posted October 12, 2019 2 hours ago, Jerry 5TJ said: You have an M20C with an IO-360-A3B6D? A curious bird. The STC is in the plane’s logs? For Overhaul basic prices — Airpower is a good place to start looking. Around $41,000 if your core is good. Stc is there(: 1 Quote Link to comment Share on other sites More sharing options...
DeltaZulu Posted October 12, 2019 Author Report Share Posted October 12, 2019 57 minutes ago, Hank said: M20-Cs were built with a carbureted O-360A1D engine of 180 hp with two magnetos. The IO-360 A3B6D is a fuel injected, dual-magneto 200 hp engine originally used in M20-Js. A few have been put into other models, but the engine STC is required, along with the more expensive engine, different cowling, different spinner and likely different engine mounts and propellor--not something done on a whim. Make sure the airplane logs clearly explain the work done, and that the STCs are present and logged to the aircraft serial number. Even then, overhaul will be much higher cost than an O-360, even without the frequent conversion: dual magneto to two magnetos. Safety Note: dual magnetos can cause complete engine failure if one side fails the wrong way. Experience Note: I have lost my left (cranking) magneto in flight, away from home, and was able to easily land without undue concern. This may or may not be possible when one side of a dual magneto fails, depending on the failure mode. Stc And paper work is there and confirmed by a mechanic and Mooney owner the Plane had a prop strike then they change engine cowling and more J stuff im trying to see what I’m going to invest in the near/far future and of curse make it safely as possible thank you for your time !!(: so dual or two? Should I keep the dual and be paranoid every oil change? Quote Link to comment Share on other sites More sharing options...
EricJ Posted October 12, 2019 Report Share Posted October 12, 2019 12 minutes ago, DeltaZulu said: so dual or two? Should I keep the dual and be paranoid every oil change? The dual mag is one of those things where you'll get a lot of strong opinions, but you should probably do your own research and just fly it for a while and see what you think. The dual mag was installed on many thousands of airplanes with various engines, many of which are still flying. I have one in my airplane and I like it, and currently plan to keep it as long as I can. There are some interesting advantages to it, and a couple funky disadvantages, but that's true of many things. It certainly shouldn't be a priority or a major concern, just an interesting feature that you may want to learn more about eventually. Bendix no longer supports them, but Kelly Aerospace makes parts and even new replacements. 1 Quote Link to comment Share on other sites More sharing options...
cliffy Posted October 12, 2019 Report Share Posted October 12, 2019 Make sure your mechanic ALWAYS uses new lock washers when ever either mounting nut is loosened on the magneto. Never reuse one of those lock washers even if the nut was just loosened to reposition the mag. Always replace the lock washer. Can be a big issue on those mags. I used them for years and never had a problem. 1 Quote Link to comment Share on other sites More sharing options...
DeltaZulu Posted October 12, 2019 Author Report Share Posted October 12, 2019 7 minutes ago, cliffy said: Always replace the lock washer. Can be a big issue on those mags. I used them for years and never had a problem. I will be on top of the maintenance for sure thank you for the help I need to learn so much 0= You ppl are amazing help! Quote Link to comment Share on other sites More sharing options...
carusoam Posted October 12, 2019 Report Share Posted October 12, 2019 DZ, Stick around... Visit often... An M20C with an IO360 is an excellent combination... Essentially you have an M20E... But you want to do some reading... M20Es were built complete at the factory.... The M20C with an E’s engine has been assembled somewhere else.... With the STC for governance... Start with the log books, and become familiar with what you have, who did it, what it needs next... Your biggest challenges are probably other things like ADSB out, and a WAAS GPS... There are several sources of things you want... search for them all... PPI insurance annual storage Engine OH cost of a cylinder transition training paint corrosion protection electronic mags All good stuff... enjoy the reading. Ask more questions. get to know the search function... ... and when to ask google... Good luck and best regards, -a- 1 Quote Link to comment Share on other sites More sharing options...
DeltaZulu Posted October 12, 2019 Author Report Share Posted October 12, 2019 35 minutes ago, carusoam said: get to know the search function... ... and when to ask google... Sorry=) im still learning “how to forum” thank you for your comment! Quote Link to comment Share on other sites More sharing options...
carusoam Posted October 12, 2019 Report Share Posted October 12, 2019 When you get practiced at forumming... you will be able to post a decent picture in under an hour and a half... Try it. Best regards, -a- 1 Quote Link to comment Share on other sites More sharing options...
RLCarter Posted October 12, 2019 Report Share Posted October 12, 2019 7 hours ago, carusoam said: When you get practiced at forumming... Would that make him a Forumite? 1 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted October 12, 2019 Report Share Posted October 12, 2019 One would have to visit the Mite section of MS to be a real Forumite!!! -a- 1 1 Quote Link to comment Share on other sites More sharing options...
