42 minutes ago, M20Doc said:
From AC20-42D:
Doc, there you go again, quoting regulations not that doesn't champion the use of a  relief tube or Winter Deicing good to -40 degrees (WD-40).  :)
On 8/8/2019 at 8:02 PM, RobertGary1 said:
Looks like H3R no longer makes the little 8”x3” one I used to use. What are other people putting in their seat pockets?
-Robert
Had same issue. Got this guy
Amerex A344T, 1.25lb Halon 1211 Class B C Fire Extinguisher
I paid 185 in Oct. Price went to 209 now on Amazon.  Is a refillable unit.
https://smile.amazon.com/gp/product/B00F5CK09O/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
https://amerexfireextinguishers.com/
17 hours ago, Seymour said:
Aviation application was asked in a Ferrari board last year and a company representative's answer and the current FAQ about UL certification are posted below (along with the links for this information):
https://www.ferrarichat.com/forum/threads/element-fire-extinguisher-an-introduction.564980/page-4
and
https://elementfire.com/pages/faqs
First Link:
Coupon codes sent
As for use in aircraft applications, we have a number of customers who have chosen to carry Element in their personal small aircraft. Many of them cite the one handed operation (after striking) as a bonus because it allows to put out a dash fire while still being able to control the aircraft. That said at present Element cannot be used to legally substitute areas where a UL certified extinguisher is required (like the annually inspected bottles in the hangar) so any decision to use these needs to be done as a supplement to whatever is required by the fire marshal. This topic is covered in greater detail in the FAQ section of our website. We have a number of customers who supplement extinguishers with Element which is totally allowed by law. Hope this helps
Second Link:
IS ELEMENT CERTIFIED?
Originating in Italy, Element has been certified for sale in Europe by CE and TUV. Institutionally it has been tested and certified for use by multiple international military and police groups who have adopted it for active use.
In North America, Underwriters Laboratories (UL) is responsible for the certification of fire extinguishers. UL does their testing to a standard that contains a form (physical shape) component followed by a performance component. Because Element's form does not fit inside of UL's guidelines of what a traditional fire extinguisher looks like (i.e. compressed gas cylinder with a hose and measurement gauge) it is immediately passed over for performance testing. At present UL is being campaigned to update its standards to recognize the different form offered by Element and allow it an opportunity to be tested and certified.
Until the standards are updated Element cannot be used to substitute extinguishers in regulated environments that require a UL (or UL endorsed) certification. Element can however be freely used as an supplement to the extinguishers used where regulation exists.
There are no restrictions in non-regulated environments (car, home, personal garage, etc.) allowing Element to be used freely.
 The Element extinguisher seems like it's truly an innovation from the standpoint of effectiveness, weight, nontoxicity, non-corrosiveness, compact form factor, and particularly ease of use.  Anyone want to buy my 1211 Halon extinguisher? (only half kidding).
17 hours ago, M20Doc said:
From AC20-42D:
I think everyone understands the regulations, now for the big questions. How do you mount one in a plane that never had one factory installed? A few years ago someone offered bracket attachment hardware for the seat lock. That was poo pooed. Where can you mount one and what hardware do you need to mount one?
I’ve mounted them on the pilots seat base below the handle or on the floor between the seats, from the J onward Mooney mounted them on the front of the main spar behind the pilot’s seat.
Thanks. I guess my local IA should know what lies beneath and/or behind these locations so drilling holes and using the correct length and type of fastener shouldn’t be an issue.
I’d like to see pictures of where people mounted things.
From the J IPC.
On the floor between the seats?  That sounds odd.  How did you modify the Johnson Bar? :)
From the J IPC.
Yep, that’s where mine is. Just try to get that out of there from the pilot’s seat - I dare you.
With one of these of course.
