willerjim273 Posted August 5, 2019 Report Posted August 5, 2019 Hello all. On the way back from OSH, my autopilot will not engage. From my reading, the panel switch is magnetic. Mine will not stay in up position. Panel fuse operates normally and makes no difference. Is there an inline fuse somewhere? Anyone have a wiring diagram? Trim works fine. tks
PT20J Posted August 6, 2019 Report Posted August 6, 2019 There’s no other fuse. Did it pass self test? Does the flight director work?
willerjim273 Posted August 6, 2019 Author Report Posted August 6, 2019 Hello, Thanks for the reply. Yes on both except no flashing lights on lamp test.
carusoam Posted August 6, 2019 Report Posted August 6, 2019 Expect when the BK AP starts up... it does a self test... the celebration of a good self test is the light and sound show... beep, beep, beep (about five or so) with a blinking light to match... This is based on fuzzy memory of a KAP150... slightly newer than the KFC200... It has a test protocol of all the servos, computer, and the trim servo is the one that often gets forgotten... If the trim servo CB has been shut off, the test fails, no light and sound show is given, and the AP sits there and does nothing... PP thoughts only, stuff I learned by reading the KAP book a while back... Best regards, -a-
anthonydesmet Posted August 6, 2019 Report Posted August 6, 2019 Thought I remembered seeing a similar post about a year ago. Found the post I remembered. But not totally your issue but mat help in troubleshooting. Also I highly recommend calling Autopilot Central. They will troubleshoot over the phone with you - walk you through the steps then provide a recommendation. past article: Autopilot central: http://www.autopilotcentral.com/ (918) 836-6418
squeaky.stow Posted August 6, 2019 Report Posted August 6, 2019 Just went through the same thing. Contact Bob Weber at webairconsulting.com It’s a fairly easy and cheap to fix if it is the same problem as mine. The clue is that the autopilot works if you hold the switch in the on position but it won’t magnetically latch in place. Bob can talk you or your hangar fairy through it. Mark 1
willerjim273 Posted August 7, 2019 Author Report Posted August 7, 2019 Fixed. The same problem as Mark. The magnet on the On-Off arm had slipped out of it's socket. Two cent fix. Big clue for the future is if your On-Off switch does not seem to travel like it used to, there could be something blocking it. Like the magnet. Whew! For you more experienced should I post this fix as a new post? I'd hate to see anyone pay loads of money for a loose magnet. Thanks to all.
carusoam Posted August 12, 2019 Report Posted August 12, 2019 @willerjim273 Nice work! You can edit the title a bit if you want... Great solution to a vexing challenge. One other challenge... I can’t see the video. It is easy to share videos using YouTube, then post a link here... Best regards, -a-
firelog1101 Posted July 4, 2023 Report Posted July 4, 2023 Sadly my KFC 200 is now acting up with a similar issue. Was flying home yesterday and disengaged the AP using the trim tab. Now the switch will not stay in the ON position. If I hold it up it functions fine, will hold a heading and altitude. Made a quick video to show the symptoms...
Wingfree Posted July 5, 2023 Report Posted July 5, 2023 If the magnet fell out of place it can be repositioned - if the switch cracked it may need to be replaced. KFC290 Lever Switch, p/n 088-00535-0002. It was around $225 when I looked for one last year (from wipaire.com).
firelog1101 Posted July 6, 2023 Report Posted July 6, 2023 (edited) Finally pulled out the control box and opened it up, looks like the black plastic on the switch has cracked, all the plastic is very very brittle.. Oddly I cannot find the plastic remnants unless they were dropped on removal. Just looking at the device I can't really see how the magnet holds the switch in the "on" position. I am getting in contact with the autopilot guys from Tulsa to see if they are able to fix it. I am hopeful that is it Edited July 6, 2023 by firelog1101
LANCECASPER Posted July 6, 2023 Report Posted July 6, 2023 10 hours ago, firelog1101 said: Finally pulled out the control box and opened it up, looks like the black plastic on the switch has cracked, all the plastic is very very brittle.. Oddly I cannot find the plastic remnants unless they were dropped on removal. Just looking at the device I can't really see how the magnet holds the switch in the "on" position. I am getting in contact with the autopilot guys from Tulsa to see if they are able to fix it. I am hopeful that is it Autopilots Central used to be the go-to place. Not so much anymore. They are very expensive and I've heard too many stories about how they didn't fix the problem. Talk to @Jake@BevanAviation 1
Jake@BevanAviation Posted July 6, 2023 Report Posted July 6, 2023 Pretty common failure, the control head needs a new lever switch. The plastic switch gets brittle with age and breaks. Hopefully, you found the little piece of metal that floats between the contacts. Trying to glue the switch back together does not always produce reliable results. The switch contact is designed to float for alignment to the electromagnet. When you glue the contact in place it can no longer self-align to the electromagnet and produces poor latching. The current list from Honeywell is $678.53 for the lever switch. I do have stock and will honor the old price of $241.00 plus labor. However, when I have to order more, I will have to go to the current list from Honeywell. My current lead time is 5-7 business days. 2
firelog1101 Posted July 28, 2023 Report Posted July 28, 2023 Indeed it was the switch, thanks to Bevan aviation and everyone's input it is back up and running without issue!
