Captnmack Posted January 26, 2019 Report Posted January 26, 2019 Hey guys...anyone have a good example of a W&B loading graph for C model. I have the documentation in the supplement but would like to have a quick sheet...going to take a 1.5 hour x-country with 4.. Quote
carusoam Posted January 26, 2019 Report Posted January 26, 2019 In 1965, that detail was a separate piece of graph paper with the basic math and MGTW, empty weight and UL... the piece of paper was kept with the logs, and didn’t have an important title until you are looking right at it, and those details can’t be found anywhere else... A modern POH can be found around here that has all the appropriate stations for loading four people, fuel, bags, and your hat on its own rack... The modern POH also has things like T/O distances... If you have all that... There are WnB apps everywhere... getting your data into them the first time takes some precision... No points for goofing up basic PIC responsibilities... find the pic of five people in an M20C... it’s around here somewhere... it got posted after the off field.... activity. PP thoughts only, not a CFI... Best regards, -a- Quote
Prior owner Posted January 26, 2019 Report Posted January 26, 2019 How accurate is the M20C aircraft W&B info that is in ForeFlight? Quote
0TreeLemur Posted January 26, 2019 Report Posted January 26, 2019 9 hours ago, PilotCoyote said: How accurate is the M20C aircraft W&B info that is in ForeFlight? I can verify that the envelope is correct for the C. 1 Quote
0TreeLemur Posted January 26, 2019 Report Posted January 26, 2019 Here is a form I found online for a 1965 C model. Looks to be a scanned copy of a Mooney document. M20C_Weight_Balance_Data_Form_1965.pdf Quote
DXB Posted January 26, 2019 Report Posted January 26, 2019 Here's the excel spreadsheet one I used for my C before I switched to Foreflight. Plug in your numbers and it should work for you. Weight and balance.xlsx 1 Quote
1967 427 Posted January 26, 2019 Report Posted January 26, 2019 Aren't there app's for that? I downloaded WnB Pro, for one reason only (ramp check! !) in seconds you can show your inside the envelope. Obviously the information is only as good as your setup of arms and weights. In cross checking the app it is accurate, but it really is't anything above a pretty excel spreadsheet. Quote
Hank Posted January 26, 2019 Report Posted January 26, 2019 I found a similar spreadsheet and added a second page to it with a variety of loading configurations. It was simple to figure several different passenger / baggage loadings and add line for 50, 40, 30 and 20 gal for each to cover landings and partial fuel trips. I keep a printout of this in the plane; those scenarios that are out of CG are in red for quick reference. In the event that anyone asks (zero occurences since purchase in June 2007), it's there. More importantly, it was quite beneficial when learning the aircraft. A quick glance confirmed that I was good, or told me to calculate it if it was close. It also let me compare flight characteristics to the loading when reflecting afterwards. So play with the spreadsheet and build a tabke of results. You may have some happy surprises! Quote
Captnmack Posted January 29, 2019 Author Report Posted January 29, 2019 On 1/26/2019 at 9:02 AM, Fred₂O said: Here is a form I found online for a 1965 C model. Looks to be a scanned copy of a Mooney document. M20C_Weight_Balance_Data_Form_1965.pdf Yeah..I have all that too. I used it to do my calculations and all was well. I had one made up for an Apache Years back. thx. Quote
MinneMooney Posted January 29, 2019 Report Posted January 29, 2019 I am wondering if the calculated arm on my ‘65C is correct. My empty weight is 1607# but the arm seems a bit forward at 44.66”. So much so that I have to be careful with 2 on board and full fuel not to be too nose heavy. It would be a pain to redo all of the wt & balance calculation I have, but after reading on the blog, I’m not that confident in having someone use portable scales either. Quote
Prior owner Posted January 29, 2019 Report Posted January 29, 2019 My ‘64 D is also very close to the forward CG limit with 400 lbs up front and full fuel. Quote
ArtVandelay Posted January 29, 2019 Report Posted January 29, 2019 My ‘64 D is also very close to the forward CG limit with 400 lbs up front and full fuel. That’s while short bodies are benign during stalls, my J is close to rear when just myself and some luggage.Tom 1 Quote
Prior owner Posted January 29, 2019 Report Posted January 29, 2019 33 minutes ago, ArtVandelay said: That’s while short bodies are benign during stalls, my J is close to rear when just myself and some luggage. Tom Learning something new everyday here! Quote
0TreeLemur Posted January 29, 2019 Report Posted January 29, 2019 4 hours ago, Captnmack said: Yeah..I have all that too. I used it to do my calculations and all was well. I had one made up for an Apache Years back. thx. Apache...? Are you talking about the rare Mooney Apache, or as in hover & kill Apache? I assume the latter. Quote
Captnmack Posted January 30, 2019 Author Report Posted January 30, 2019 6 hours ago, Andy95W said: Probably a Piper Apache Yes...PA 23-160..... Quote
