Robert c Posted September 11, 2018 Author Report Posted September 11, 2018 Thanks for all the insite i have built two pitts wings and a skybolt wing plus i restored a 1946 cessna 140 just love bringing back the old planes always wanted a mooney. No money but i do have time to play in the garage. Spending a little at a time is easier then all at once. The 140 is mine the rest have been sold 2
steingar Posted September 11, 2018 Report Posted September 11, 2018 My goodness you have mad skills! Like I said, you can find a derelict Mooney that will make a much better project. Any derelict is likely to take more to resurrect than its worth, but you should at least find a project where its all there. Lots of them about too, the teens have not been kind to many Mooneys.
MB65E Posted September 11, 2018 Report Posted September 11, 2018 Nice work Robert!! If the fuselage was clean, I’d personally go for it then! I saw your black and blue S1C at King City a few years ago. Just think big model airplanes!! -Matt
Robert c Posted September 11, 2018 Author Report Posted September 11, 2018 Thay say that it is all there. Thay cut the wings off because the wife woodent stop flying it after thay found bad spots in the spars under the body of the plane
carusoam Posted September 11, 2018 Report Posted September 11, 2018 Wood... Nature’s composite material. A fantastic combination of fibers and resin. Strong and formable. Robert, if you have the construction skills, a wooden M20 may be looking for you. The drawback to be aware of was the wooden tail strength. Most have been updated to aluminum tail feathers after a really old AD. Original M20s came with 150hp and fixed pitch props. The modern version may have an O360 with 180hp... It would be really great if that comes complete with all the logs... Somebody has posted pictures around here showing the glorious woodwork that the wings are... Best regards, -a-
Shadrach Posted September 11, 2018 Report Posted September 11, 2018 Robert, I greatly admire your skills. I think if anybody could restore this Mooney, you’re likely the guy. I also think that you’ve asked for a consultation from a group of folks who have nowhere near your experience in resurrecting and/or building wooden aircraft. This project would be a no go for most. Judging from the pictures you posted, you are not most. 1 1
Robert c Posted September 11, 2018 Author Report Posted September 11, 2018 Thanks For all the inspiration. The mooney has all the logbooks from new
Guest Posted September 11, 2018 Report Posted September 11, 2018 2 hours ago, Robert c said: Thay say that it is all there. Thay cut the wings off because the wife woodent stop flying it after thay found bad spots in the spars under the body of the plane That’s a scary thought! If you want a project, there was one in Quebec that landed short. It was listed on here recently. Clarence
Hank Posted September 11, 2018 Report Posted September 11, 2018 Robert, you seem to have the mad skills that building a new wood wing requires. Go for it, but don't pay too much for the project up front . . . .
Robert c Posted September 11, 2018 Author Report Posted September 11, 2018 I was thinking that i wood put m20A alumanum wings on it
Hank Posted September 11, 2018 Report Posted September 11, 2018 1 minute ago, Robert c said: I was thinking that i wood put m20A alumanum wings on it That should work. Where are you located? Are you near Clarence and the donor M20A he mentioned just above?
Robert c Posted September 11, 2018 Author Report Posted September 11, 2018 I am in west Michigan. I have called Texas airsalvige and thay have a wing that thay can sell with miner skin damage on the top by the tank door
MikeOH Posted September 12, 2018 Report Posted September 12, 2018 Ignorant questions: Is putting a metal wing on a plane originally designed/built with a wood wing going to cause 'certification issues?' Are the wood wing and donor metal wing Mooneys under the same type certificate? Going to need a DER?
Robert c Posted September 12, 2018 Author Report Posted September 12, 2018 I dont think so the 1959 m20a is the same frame just upgraded to a aluminum tail and wing
carusoam Posted September 12, 2018 Report Posted September 12, 2018 Mike, those are good questions... Mechanics usually know where to get specific answers. A lot of standard things can be exchanged using proper documents to support the work. There are a few Mooneys flying around here that have mismatched wings/fuselages... The M20A, B, and C are very similar... as they were built only a handful of years apart... The wing of 65C might be better than some of the others... flush rivets and updated 52 gal. fuel tanks with flush fuel caps... Rudder parts for increased rudder deflection also improved with the C... For the price of a 65C’s wing, you can probably buy it with a fuselage already mounted to it.... may be somewhat defeating the OP’s project ideas... PP thoughts only, not a mechanic... Best regards, -a-
kerry Posted September 12, 2018 Report Posted September 12, 2018 A M20B model wing would work. I don't think a C would. I think you would be better off finding a wood wing from a project. They are out there for little money. I'm biased but a pristine wood wing is a much better wing for a short body in all aspects. People spend thousands of dollars on speed mods and you can spend thousands less for the best speed mod(a wood wing). Plus you get aluminum fuel tanks. You never have to worry about resealing a wet tank. 2
steingar Posted September 12, 2018 Report Posted September 12, 2018 I've read Mooneys lost a good ten knots when they made the wings metal.
MBDiagMan Posted September 12, 2018 Report Posted September 12, 2018 I too am smitten with my rag wing 140. you may very well be right for such a project Robert.
MBDiagMan Posted September 12, 2018 Report Posted September 12, 2018 2 hours ago, steingar said: I've read Mooneys lost a good ten knots when they made the wings metal. Yeah, Al and Art had pretty well perfected wood wing design and construction by Al’s 20th design.
Jerry 5TJ Posted September 12, 2018 Report Posted September 12, 2018 At your first post I suspected you might be a novice looking for a cheap plane. Given your experience I (we) are happy you’re considered a rebuild of a wood wing Mooney. I’d be happy to fly one if I or someone I trust had recently rebuilt the wings. I suspect the Mooney wing, tapered so each rib is unique, will be a challenge. At least you have the original wings to use as dimensional guides or jigs. Best luck.
Robert c Posted September 12, 2018 Author Report Posted September 12, 2018 Thanks i contacted mooney and got a m20a wing repair papper that thay use to repair wings in the factory. Thay where happy to help but woodent give up wing prints to build a new wing. Cant say that i didnt try.lol 2
Robert c Posted September 13, 2018 Author Report Posted September 13, 2018 Looks like i am back to looking for a mooney she wont come down on there price. Eneyone know of a mooney sitting in a hanger waiting for someone like me to take it home????
Marauder Posted September 13, 2018 Report Posted September 13, 2018 Looks like i am back to looking for a mooney she wont come down on there price. Eneyone know of a mooney sitting in a hanger waiting for someone like me to take it home???? M20Doc talked about a plane he knows about. Also check with Alan Fox on this site. He is our Sanford & Son who does a fair amount of stripping down of non-flying planes. He might know of a Mooney looking for a home. Sent from my iPhone using Tapatalk Pro
kerry Posted September 13, 2018 Report Posted September 13, 2018 2 hours ago, Robert c said: Looks like i am back to looking for a mooney she wont come down on there price. Eneyone know of a mooney sitting in a hanger waiting for someone like me to take it home???? https://www.barnstormers.com/cat.php?mode=listing&main=
