The pump pictured is a Dukes, best overhaul price is Aero Motors LLC in Wisconsin.  The Weldon is the even better version.  However if your Dukes still makes good pressure it may not need an overhaul.
Depending on which model of Dukes pump you have you may also have an Airmaze in line filter between the pump and the firewall in the same compartment as the pump.
The fuel pump is making great pressure so it will stay.
Starter is in and I’m working on the gasket. I’ll use sharpened cans of appropriate size to cut holes in rubber mat...wait for photos and it will make sence.
Nice sharp detailed photo, PIC.
Looking forward to the other photos... :)
Looks like some timing lines marked on the starter gear.  You can even see the wear on the gear's teeth from when the starter engages and pushes it around...
The safety wire on the Inter-Av alternator mounting bolt is missing.
Doc, you are GOOD!
I went back to review the pic, I can barely see an alternator, never mind the bolt and missing detail.
Thanks for sharing your expertise! :)
best regards,
That mark on the flywheel is actually where I started counting teeth to make sure it was the right number...I think it was 149 teeth.  At the time I verified it I knew but not sure now.
Yep, I started to remove the alternator to get the starter off.  Yes, good eye.
There are missing bolts...3 to be exact.  You guys are good.
Wait, are you guys talking about the one in the case?  Is it missing or just not used?
I’m ordering a new gascolator screen and gasket.
The old one was pinched.  We are pulling the injectors so I’ll make sure if anything got past it they are not clogged but if I’m not mistaken there is another filter past the auxiliary fuel pump.
What micron is the screen?
Looks like the gasket is 2”x1/8”
Tim
I don’t believe there is an issue fitting the 149NL in, after all the original Prestolite was even bigger.
Just installed a 149NL on my F. No clearance issues. Works great! Love the starter!
Sent from my XT1585 using Tapatalk
Here are a couple picsc79238cad6aed821d45ee41cbb7ca04c.jpgdc25785655916043e02cabe313486891.jpg
For the screen details it might be easy to call the good people at Lasar...
Probably something they have a stack of for a Fin or a sawbuck...  just a guess on my part.
That brings up another question.  The boot from the power boost into the fuel injection body has at least 1 hole.  Some guys are saying to patch it.  Do you guys have any experience with that?
LASAR was out but should have some more in for a few bills.
That boot is one of the weakest pieces of garbage in our airplanes... I am not an A&P or IA but "I have a friend" with a boot patched after holes developed in a new one quickly (use fuel tank sealant) and it has held up great.
if it has a mooney part number, it comes from Mooney...
If it has a Lasar part number, it comes from Lasar...
Asking Lasar directly has always gotten a direct reply with no surprises.  Some personnel changes have occurred with the retirement and change of ownership.
But no changes in quality of parts and services have been noted...
PP thinking only, Not a mechanic...
While the intake boot is expensive and not of great quality, I would be worried about pieces of repair material being ingested by the engine or fuel servo.  An engine failure would cost significantly more than a new boot.
I can understand that concern, but have you seen the inside of the boot when it begins to disintegrate? It flakes apart and those chunks of the smooth inner lining go straight into the servo and induction system.
Edited by Immelman
7 hours ago, Pictreed said:
Looks like a LASAR part?  I'll order it tomorrow.
That’s a Mooney part number on it.
I‘I’ve seen the deterioration and have changed a few in my time.  The engine can ingest small flakes, but a chunk of PRC which is plugging a hole?
Hopefully the new boot will be in by Friday from LASAR with a new gascolator gasket and o-rings.  Someone didn’t have the proper gasket and shaved this one down...pic.
We found a cross threaded fuel injector line this weekend.  So hopefully fixing that clears up some minor back firing issues when the engine is started back up after fueling or such.
That's the before pic...
Under all the oxidation is probably a nice copper colored shine waiting to come through!
Got an after pic to go with that?
Not sure if this washer is suppose to be zinc that goes to the solenoid?  So I’m putting a brass flat washer on it.
