peevee Posted December 14, 2017 Report Posted December 14, 2017 they sell them for 6AMU but I've seen reference elsewhere to people building their own, anyone done it? Quote
Guest Posted December 15, 2017 Report Posted December 15, 2017 On 12/14/2017 at 4:21 PM, peevee said: they sell them for 6AMU but I've seen reference elsewhere to people building their own, anyone done it? Expand We have a large 2-1/2 gallon pressure pot for purging the system when needed. Clarence Quote
aviatoreb Posted December 15, 2017 Report Posted December 15, 2017 On 12/15/2017 at 1:30 AM, M20Doc said: We have a large 2-1/2 gallon pressure pot for purging the system when needed. Clarence Expand What's that? Quote
Stnelson903 Posted December 15, 2017 Report Posted December 15, 2017 On 12/14/2017 at 4:21 PM, peevee said: they sell them for 6AMU but I've seen reference elsewhere to people building their own, anyone done it? Sorry to sound dumb, but what is a amu?Sent from my iPhone using Tapatalk Quote
Yetti Posted December 15, 2017 Report Posted December 15, 2017 Aviation Monetary Unit = $1000.00 USD It takes the sting out of buying Aviation parts that have a fancy metal label that can also be found on an old tractor for $50.00 1 Quote
Dream to fly Posted December 15, 2017 Report Posted December 15, 2017 On 12/15/2017 at 2:18 PM, Yetti said: Aviation Monetary Unit = $1000.00 USD It takes the sting out of buying Aviation parts that have a fancy metal label that can also be found on an old tractor for $50.00 Expand NOW THAT IS FUNNY!!!!!. and so true Quote
philiplane Posted December 15, 2017 Report Posted December 15, 2017 any pressure pot, like those used for painting, will provide the pressure to purge the TKS system. However, if you don't use adequate filtration, you will ruin the TKS panels by clogging the pores with contaminants. Quote
peevee Posted December 15, 2017 Author Report Posted December 15, 2017 On 12/15/2017 at 3:36 PM, philiplane said: any pressure pot, like those used for painting, will provide the pressure to purge the TKS system. However, if you don't use adequate filtration, you will ruin the TKS panels by clogging the pores with contaminants. Expand The diagram in the AMM shows there are at least two inline filters. We would use fresh fluid and not recapture purged fluid, I think we can get away with just one filter. Not sure. Quote
glenn reynolds Posted February 21, 2018 Report Posted February 21, 2018 Perhaps you guys could help a TKS owner understand more about my system. When would you use this device? I test run my TKS system on the ground each month to verify that each panel is flowing correctly. Is this cart a repair item? thanks Quote
Cruiser Posted February 21, 2018 Report Posted February 21, 2018 Sounds like you are doing fine. The cart is used to purge the system when some panels are clogged and not working. Quote
Piloto Posted February 22, 2018 Report Posted February 22, 2018 I just coat the leading edge with Rain-X for plastic ($5.00). So far no ice here in Florida neither in Pittsburgh during Xmas time. José Quote
takair Posted February 23, 2018 Report Posted February 23, 2018 On 2/22/2018 at 10:17 PM, Piloto said: I just coat the leading edge with Rain-X for plastic ($5.00). So far no ice here in Florida neither in Pittsburgh during Xmas time. José Expand You are going to get kicked out of the WD-40 fan club. Quote
