carusoam Posted April 5, 2017 Report Posted April 5, 2017 Keep in mind the JPI 700 won't respond in any less than 6 seconds for some. One data point each six seconds...let it run... Best regards, -a- 1 Quote
PTK Posted April 5, 2017 Report Posted April 5, 2017 The default record interval on EDM is every 6 sec. But you can change it to record anywhere from every 2 seconds up to every 3 minutes. At least that's what it is on my EDM800 and I imagine all JPI's are the same. Personally I prefer the highest data resolution I can get so I have it capturing every 2 seconds. On a LOP mag check at altitude I let it run at least 20 sec on each mag. Quote
par Posted April 5, 2017 Author Report Posted April 5, 2017 I have an EDM-830 set to 2-sec intervals. I'll try to do this check over the weekend. Quote
carusoam Posted April 5, 2017 Report Posted April 5, 2017 The JPI 700 is 20year old technology and may not have a shorter interval... it was speed and memory limited compared to the more modern tech... Important to know..., the mechanical devices don't react much faster. it is good to have more data, quicker, but it doesn't change the time needed to better assess the engines response to the ignition key's position. Ross gave a good time line for the physical part. Best regards, -a- Quote
Greg_D Posted April 6, 2017 Report Posted April 6, 2017 The JPI EDM 700 recording interval can be set anywhere between 2 and 500 seconds. The factory default is 6 seconds. Quote
