Does anyone have the correct part no. for the AN-3 fuel strainer/Gascolator bolt seal on the base of the H&E 769 unit? I'm not looking for the 2" seal that is sandwiched between the bowl and the body. I've searched this site and others including the Stat-o-Seal nomenclature break-down PDF and there seems to be  lots of "it would work" options. Nothing is listed in either my parts catalog or service manual. Lastly, the part no. for the O-ring for the selector valve itself?. Help! :unsure:
I'm curious? Why is there is no technical reference or DIY section on this site?
Edited by Z00mie
Dan at lasar has the entire kit!
Also, genuin aircraft hardware (PRB) has the seals as well.
Best,
-Matt
