Hi all..
Noticed a bolt missing on the exhaust where the exhaust pipe connects to the muffler. Is there a part number associated with that bolt spring nut and cotter pin or do I just order the various pieces to put together?
Thanks again
GHW
3 hours ago, George said:
1964 M20c 2746
George,
It should be an AN3-15 bolt, an AN310-3 nut, a pair of AN 960-10 washers and a 186-218 spring.  The entire tail pipe requires this time 3.  The AN stuff should be stock at any shop, the spring is the same as the ones used in Cessna twin exhaust systems.  Likely easier to find on most fields than a Mooney spring.
