dooleypster Posted September 3, 2016 Report Posted September 3, 2016 Is there any reg, etc against relining your own brake pads? There's a simple tool that will drive the old rivets out and the new rivets in. Does this come under minor maintenance? Quote
Bob_Belville Posted September 3, 2016 Report Posted September 3, 2016 I have done brake relining for years but I always have had my A&P sign off. I think this is the operative reg: I do not see brake lining replacement. I would understand that to mean is is not permitted w/o an A&P. Appendix A to Part 43 ... (c) Preventive maintenance. Preventive maintenance is limited to the following work, provided it does not involve complex assembly operations: (1) Removal, installation, and repair of landing gear tires. (2) Replacing elastic shock absorber cords on landing gear. (3) Servicing landing gear shock struts by adding oil, air, or both. (4) Servicing landing gear wheel bearings, such as cleaning and greasing. (5) Replacing defective safety wiring or cotter keys. (6) Lubrication not requiring disassembly other than removal of nonstructural items such as cover plates, cowlings, and fairings. (7) Making simple fabric patches not requiring rib stitching or the removal of structural parts or control surfaces. In the case of balloons, the making of small fabric repairs to envelopes (as defined in, and in accordance with, the balloon manufacturers' instructions) not requiring load tape repair or replacement. (8) Replenishing hydraulic fluid in the hydraulic reservoir. (9) Refinishing decorative coating of fuselage, balloon baskets, wings tail group surfaces (excluding balanced control surfaces), fairings, cowlings, landing gear, cabin, or cockpit interior when removal or disassembly of any primary structure or operating system is not required. (10) Applying preservative or protective material to components where no disassembly of any primary structure or operating system is involved and where such coating is not prohibited or is not contrary to good practices. (11) Repairing upholstery and decorative furnishings of the cabin, cockpit, or balloon basket interior when the repairing does not require disassembly of any primary structure or operating system or interfere with an operating system or affect the primary structure of the aircraft. (12) Making small simple repairs to fairings, nonstructural cover plates, cowlings, and small patches and reinforcements not changing the contour so as to interfere with proper air flow. (13) Replacing side windows where that work does not interfere with the structure or any operating system such as controls, electrical equipment, etc. (14) Replacing safety belts. (15) Replacing seats or seat parts with replacement parts approved for the aircraft, not involving disassembly of any primary structure or operating system. (16) Trouble shooting and repairing broken circuits in landing light wiring circuits. (17) Replacing bulbs, reflectors, and lenses of position and landing lights. (18) Replacing wheels and skis where no weight and balance computation is involved. (19) Replacing any cowling not requiring removal of the propeller or disconnection of flight controls. (20) Replacing or cleaning spark plugs and setting of spark plug gap clearance. (21) Replacing any hose connection except hydraulic connections. (22) Replacing prefabricated fuel lines. (23) Cleaning or replacing fuel and oil strainers or filter elements. (24) Replacing and servicing batteries. (25) Cleaning of balloon burner pilot and main nozzles in accordance with the balloon manufacturer's instructions. (26) Replacement or adjustment of nonstructural standard fasteners incidental to operations. (27) The interchange of balloon baskets and burners on envelopes when the basket or burner is designated as interchangeable in the balloon type certificate data and the baskets and burners are specifically designed for quick removal and installation. (28) The installations of anti-misfueling devices to reduce the diameter of fuel tank filler openings provided the specific device has been made a part of the aircraft type certificiate data by the aircraft manufacturer, the aircraft manufacturer has provided FAA-approved instructions for installation of the specific device, and installation does not involve the disassembly of the existing tank filler opening. (29) Removing, checking, and replacing magnetic chip detectors. (30) The inspection and maintenance tasks prescribed and specifically identified as preventive maintenance in a primary category aircraft type certificate or supplemental type certificate holder's approved special inspection and preventive maintenance program when accomplished on a primary category aircraft provided: (i) They are performed by the holder of at least a private pilot certificate issued under part 61 who is the registered owner (including co-owners) of the affected aircraft and who holds a certificate of competency for the affected aircraft (1) issued by a school approved under §147.21(e) of this chapter; (2) issued by the holder of the production certificate for that primary category aircraft that has a special training program approved under §21.24 of this subchapter; or (3) issued by another entity that has a course approved by the Administrator; and (ii) The inspections and maintenance tasks are performed in accordance with instructions contained by the special inspection and preventive maintenance program approved as part of the aircraft's type design or supplemental type design. (31) Removing and replacing self-contained, front instrument panel-mounted navigation and communication devices that employ tray-mounted connectors that connect the unit when the unit is installed into the instrument panel, (excluding automatic flight control systems, transponders, and microwave frequency distance measuring equipment (DME)). The approved unit must be designed to be readily and repeatedly removed and replaced, and pertinent instructions must be provided. Prior to the unit's intended use, and operational check must be performed in accordance with the applicable sections of part 91 of this chapter. (Secs. 313, 601 through 610, and 1102, Federal Aviation Act of 1958 as amended (49 U.S.C. 1354, 1421 through 1430 and 1502); (49 U.S.C. 106(g) (Revised Pub. L. 97-449, Jan. 21, 1983); and 14 CFR 11.45) [Doc. No. 1993, 29 FR 5451, Apr. 23, 1964, as amended by Amdt. 43-14, 37 FR 14291, June 19, 1972; Amdt. 43-23, 47 FR 41086, Sept. 16, 1982; Amdt. 43-24, 49 FR 44602, Nov. 7, 1984; Amdt. 43-25, 51 FR 40703, Nov. 7, 1986; Amdt. 43-27, 52 FR 17277, May 6, 1987; Amdt. 43-34, 57 FR 41369, Sept. 9, 1992; Amdt. 43-36, 61 FR 19501, May 1, 1996; Amdt. 43-45, 77 FR 71096, Nov. 29, 2012] Quote
Mooneymite Posted September 3, 2016 Report Posted September 3, 2016 Once when I was repacking my wheel bearings, I set the brake pads off to the side and when I went to reinstall, they looked brand new. Not sure what happened. My IA was perplexed, too, but after a thorough insprction he signed thd job off. 4 Quote
Hank Posted September 3, 2016 Report Posted September 3, 2016 We are allowed under Owner Maintenance to remove the brakes so that the wheels may be removed, split, tires & tubes replaced, bearings removed and repacked. But we aren't allowed to replace the brake pads . . . unless working under A&P supervision. Doesn't make much sense to me, but what do I know??? 1 Quote
dooleypster Posted September 3, 2016 Author Report Posted September 3, 2016 Thanks Bob and Mooneymite.....good answers. Quote
Guest Posted September 3, 2016 Report Posted September 3, 2016 4 hours ago, Mooneymite said: Once when I was repacking my wheel bearings, I set the brake pads off to the side and when I went to reinstall, they looked brand new. Not sure what happened. My IA was perplexed, too, but after a thorough insprction he signed thd job off. You may have had a Texas Hangar Elf pass through the hangar. They are known for being crafty! Clarence Quote
Mooneymite Posted September 3, 2016 Report Posted September 3, 2016 Just now, M20Doc said: You may have had a Texas Hangar Elf pass through the hangar. They are known for being crafty! Clarence Clarence, as much work as those Elves seem to do, you'd think they'd have an A&P by now. Unfortunately, they only do undocumented work....you know what that's worth! Quote
cliffy Posted September 4, 2016 Report Posted September 4, 2016 To answer the OP directly- No you can't change the brake pads yourself unless you have it signed off by an A&P Yes there are a couple of good tools for the job made by Rapco. The best one uses a screw and T handle to drive the old rivets out and to set the new rivets. Much better "feel" on setting the rivets than using the "hammer" style setting tool. Both need a good vice to hold them. No it is not considered "preventive maintenance" that an unlicensed person can do without A&P supervision. It's and easy job but requires skills at tightening the caliper bolts correctly, setting the rivets and doing a respectable job of safety wiring where or when required. Quote
