I am selling a Stratus 2 that I picked up. The unit works great and performs and picks up as it should. It will operate fine with power plugged in. Using battery it seems that the battery life is a little short. I thought about sending it to Appareo and have them take a look at the battery, but since I have GDL88 I really don't want to take the time. It will operate all day plugged in. On battery with a full charge it lasts about 3 hrs +/-. It will charge 100% when put back on a charger..Might need a new battery if you want to go wireless or just use it plugged in and powered on ships power and not worry about it. This is not the S. This is the version 2 though.
I'm pricing it cheap enough to run either way.. All the functions work as they should including the fan..I've used it with ships power with NO problems at all.
First $300 takes it and you get what is pictured.. I'll even cover shipping to lower 48.
-Tom
