sheetsg Posted November 26, 2010 Report Posted November 26, 2010 For the past two months, I've been working on the interior of my M20J ('84). It all started with the desire to update to panel with WAAS capability, and in an effort to reduce costs, I would remove the interior panels before the installation. Well, the panels were yellow/orange-ish in color (originally an off-white color), the seats looked "OK-ish", but dated in colors, the yokes were suffering from severe flaking, and the insulation was minimal. So, I removed the seats and shipped them to AirTex Interiors to be covered in leather. The panels were removed, repaired as required, then repainted using the SEM "color coat" paint. I used Santa Fe and Satin Black, followed by a coat of clear coat. The old insulation, a mixture of fiberglass and thin (1/2 ") closed cell, was removed and replaced with a M20J SoundEx insulation kit. The yokes were covered by AeroComfort with leather and the new Mooney logo. Besides the great looks, they feel really nice in the hand too. I found that the fresh air scoop in the co-pilot side also emits water into the hoses, both over the behind the panel to the pilot side air vent and to the cabin vent control valve. Both hoses had to be replaced as the metal coil inside each was rusted and had penetrated the fabric covering. Finally, the panel was upgraded (Exxel Avionics) by replacing the KNS-80 with a G430W augmented with an Aero 560 with XM Weather and crossfill from the 430W. I also upgraded to PS Engineering 8000B panel and added intercom jacks for the rear pax too. I bought some 3 mil Al foil to back the new placards (High Plane Graphics), and have yet to attach them. A few leather inserts also need to be taped into place. But, its almost done! I'm quite happy with the results. Greg. P.S. Credit must be given to Mooney201.com for the inspiration on the color and armrest modifications to cover the unused ashtrays. Quote
M016576 Posted November 26, 2010 Report Posted November 26, 2010 Quote: sheetsg For the past two months, I've been working on the interior of my M20J ('84). It all started with the desire to update to panel with WAAS capability, and in an effort to reduce costs, I would remove the interior panels before the installation. Well, the panels were yellow/orange-ish in color (originally an off-white color), the seats looked "OK-ish", but dated in colors, the yokes were suffering from severe flaking, and the insulation was minimal. So, I removed the seats and shipped them to AirTex Interiors to be covered in leather. The panels were removed, repaired as required, then repainted using the SEM "color coat" paint. I used Santa Fe and Satin Black, followed by a coat of clear coat. The old insulation, a mixture of fiberglass and thin (1/2 ") closed cell, was removed and replaced with a M20J SoundEx insulation kit. The yokes were covered by AeroComfort with leather and the new Mooney logo. Besides the great looks, they feel really nice in the hand too. I found that the fresh air scoop in the co-pilot side also emits water into the hoses, both over the behind the panel to the pilot side air vent and to the cabin vent control valve. Both hoses had to be replaced as the metal coil inside each was rusted and had penetrated the fabric covering. Finally, the panel was upgraded (Exxel Avionics) by replacing the KNS-80 with a G430W augmented with an Aero 560 with XM Weather and crossfill from the 430W. I also upgraded to PS Engineering 8000B panel and added intercom jacks for the rear pax too. I bought some 3 mil Al foil to back the new placards (High Plane Graphics), and have yet to attach them. A few leather inserts also need to be taped into place. But, its almost done! I'm quite happy with the results. Greg. P.S. Credit must be given to Mooney201.com for the inspiration on the color and armrest modifications to cover the unused ashtrays. Quote
sheetsg Posted November 26, 2010 Author Report Posted November 26, 2010 Joe, The panels are paint only, but the work is in the preparation of the panels. I also painted the screws and washers to make them blend into the panel. I sprayed 3 coats of color followed by two layers of clear coat. The clear coat gave the appearance of "depth", to the panel and also adds a layer of scratch resistance. I used the SEM product line for preparation, namely soap & water scrub, followed by SEM scrub, then SEM vinyl prep, then just before painting, SEM Sand Free (an acetone spray to aid adhesion). AirTex Interiors supplied both the armrests and inserts. I provided Airtex with a new "z-shaped" base for the armrest, and they covered them. This was the first time they did this way, and they said they liked the idea and would use it again. Greg Quote
Immelman Posted November 26, 2010 Report Posted November 26, 2010 Wonderful! I am slowly updating my interior using SEM paint, and will replace some of the really nasty looking panels.. it really makes a difference. If you don't mind, how much did sending the seats to airtex for leather re-upholstery cost? After I get done, the seats are my next target, but that is a job I'll leave for the pros. Quote
M016576 Posted November 26, 2010 Report Posted November 26, 2010 Quote: sheetsg Joe, The panels are paint only, but the work is in the preparation of the panels. I also painted the screws and washers to make them blend into the panel. I sprayed 3 coats of color followed by two layers of clear coat. The clear coat gave the appearance of "depth", to the panel and also adds a layer of scratch resistance. I used the SEM product line for preparation, namely soap & water scrub, followed by SEM scrub, then SEM vinyl prep, then just before painting, SEM Sand Free (an acetone spray to aid adhesion). AirTex Interiors supplied both the armrests and inserts. I provided Airtex with a new "z-shaped" base for the armrest, and they covered them. This was the first time they did this way, and they said they liked the idea and would use it again. Greg Quote
thinwing Posted November 30, 2010 Report Posted November 30, 2010 verynice work..thanks for sharing..kpc Quote
fantom Posted November 30, 2010 Report Posted November 30, 2010 Greg.....you're invited down to SoFL and bring your spray gun ;-) Quote
Parker_Woodruff Posted November 30, 2010 Report Posted November 30, 2010 Really nice improvement. Quote
scottfromiowa Posted November 30, 2010 Report Posted November 30, 2010 W.O.W! Fantastic work. Can you elaborate on the SEM paint? Is this a professional auto body shop type gun/application? Where can this be purchased? When you talk about a black in the paint are these mixed, or is a black a base? I really like your result. My headliner is a cloth material. Can this material actually be painted like the plastics or must it be replaced? Thanks in advance for education. If you have any photos of actual process I would love to see this, or photos of the SEM paint/process. Thanks, Scott Quote
Bacachero Posted December 1, 2010 Report Posted December 1, 2010 Awesome Can you share the costs involved in the leather work and the paint work? Quote
Bacachero Posted December 1, 2010 Report Posted December 1, 2010 Found this interesting SEM Aerospace training video on youtube http://www.youtube.com/watch?v=w035eKcgiAQ Quote
sheetsg Posted December 5, 2010 Author Report Posted December 5, 2010 Breakdown on costs (approx) Leather seats: $2,200 (plus an additional $800 to expedite in AirTex shop) Carpet, vinyl leather inserts, vinyl leather armrests, door and baggage welt, and kick panels : $1000 Paint (8 16oz cans SEM Santa Fe, 4 16 oz cans SEM clear satin, 2 16 oz cans SEM black satin, 2 cans 16 oz SandFree, 2 16oz cans Vinyl Prep, 1 tube SEM Scrub, 1 can gray prime/etch) : $300 Labor in prep (cleaning off old Velcro from window shades, repair of minor cracks and broken holes) ~ 40 hrs Labor in removal of panels and old carpet : ~40 hrs Labor in paint : ~ 10 hrs (3 coats of color, followed by 2 coats of clear, 20 min in between coats) Labor to reinstall panels and carpets: ~ 30 hrs (mostly trimming carpet and kick panels for aircraft) Tip: Used CRC Brakleen to soften and remove old carpet glue from aircraft and plastic panels - but you need plenty of ventilation Quote
