Darrolio Posted February 3, 2020 Report Posted February 3, 2020 On 1/28/2020 at 3:13 AM, kmyfm20s said: He should have 2 thin binders that came with the STC. In the binder it shows the gross weight increase to 3368 lbs, which bring the Eagle up to the same GW as the Ovation. Show the binders to your mechanic and have a new W&B made for your POH. Thanks team! My father is looking for the STC binders. He did note that his RPM only increased from 2400 to 2500 (vs. the 2700 stated in the article). Quote
M20S Driver Posted February 4, 2020 Report Posted February 4, 2020 I had one of the original STCs, changing the RPM to 2500 and no GW increase. I upgraded to 310HP, 2700 rpm, which came with extra 168 lb of GW making it 3368 lbs. Quote
carusoam Posted February 4, 2020 Report Posted February 4, 2020 2500 rpm is 280hp, typical of the O1... 2700 rpm is 310hp, typical of the O3... Both the O1 and O3have the same MGToW... Obviously it pays to have the most updated STC as possible to get it all, legally... PP thoughts only, not a mechanic... Best regards, -a- Quote
