Noticed an unusually hot EGT in cruise lately. Been trying to figure it out a while. Recently did an in-flight mag check. On one mag the rise is normal but on the other, this specific cylinder rises way more than usual. It was 1600 and still climbing when I went back to both. This explains the high EGT in cruise cause it averaged out the good and bad plug. What can cause an EGT to be hotter on just one mag on just one cylinder?
I would start with the spark plug.  You can swap them top to bottom.  Next would be harness and then magneto.  Probably weak spark on that plug.
Why would weak spark lead to higher EGT? Delayed burn?
Hi! Correct. Sounds like a failing plug. However, I'd pull the injector on the hot cylinder. I have had clogged injectors do strange things. It's shocking on how little debris it takes to have an issue.
good luck!
-Matt
1 hour ago, takair said: I would start with the spark plug.  You can swap them top to bottom.  Next would be harness and then magneto.  Probably weak spark on that plug.
Yes, same reason 1 mag causes higher EGTs
good luck!
-Matt
I would not...
I would do one thing at a time, pulling injectors when not needed may introduce another maintenance induced problem.
I had the same problem. It was evidently a weak spark on one plug. Right after taking off and while in the pattern I noticed the same high exhaust temp but relatively cool cylinder. I returned to the ground and pulled and cleaned both plugs. I started aggressively leaning the mixture immediately after start up and never had the problem again.
It's not a fouled plug. It's not injectors, had them cleaned since the problem started and made zero difference. It's not the timing cause I had it checked. Must be a bad plug. Do you replace just the one?
3 hours ago, nels said: I had the same problem. It was evidently a weak spark on one plug. Right after taking off and while in the pattern I noticed the same high exhaust temp but relatively cool cylinder. I returned to the ground and pulled and cleaned both plugs. I started aggressively leaning the mixture immediately after start up and never had the problem again.
If they are Champions, I would replace them all with Tempest.
They are Champions. Came with the factory reman. So running them till they need replacement for fine wires.
Number 3 right mag, is that top or bottom?
How many hours on the plugs? Football shaped electrodes yet?
If you replaced them all you wouldn't know which one was bad.
Trace the wires back from the mag harness. It's hard to varify online with out a diagram. That Bendix switch can be confusing.
Here are some diagrams out of the Lycoming OH manual.
For what it's worth, I really like the Tempest plugs, but wouldn't change them all as long as you can prove they test well. The cost of the fine wires is too steep for me at the moment.
You do seem to fly a lot, and would appreciate their reliability.
-Matt
