Guest Mike261 Posted May 8, 2015 Report Share Posted May 8, 2015 there is quite a good deal of information on the site about fuel bladders. I am however confused about the fuel caps. conflicting info. are they relocated? different cap types? I would like to retain the original cap location and a flush cap. anyone have any pictures of a completed install, I couldn't find anything on the o and n site. thanks mike Quote Link to comment Share on other sites More sharing options...
Marauder Posted May 8, 2015 Report Share Posted May 8, 2015 Mike - the current bladder systems use a different cap system than the older versions. Both however, keep the filler hole in the same location. I just happen to take a picture of the new style off of Dev's plane. Let me find it and post it. Found it: I have bladders in my plane for the past 24 years. No issues... Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Marauder Posted May 8, 2015 Report Share Posted May 8, 2015 BTW - didn't know the new style has locks on them! Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Guest Mike261 Posted May 8, 2015 Report Share Posted May 8, 2015 thanks for the pic. seems to me i read somewhere they had to change the cap, can't remember the reason mike Quote Link to comment Share on other sites More sharing options...
Guest Mike261 Posted May 8, 2015 Report Share Posted May 8, 2015 did you have them installed by your local a&p? Quote Link to comment Share on other sites More sharing options...
Marauder Posted May 8, 2015 Report Share Posted May 8, 2015 did you have them installed by your local a&p?Raised caps were part of the original AD submission. It was later removed as part of the review but was offered as an option to those of us impacted by the AD. I remembered them because they looked like Piper caps. I opted to stay with the Shaw ones. As Jim points outs below, the newer style caps became available late due to other reasons. I had mine installed at the source O&N. The AD mods were done by my AI. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
rbridges Posted May 9, 2015 Report Share Posted May 9, 2015 The new caps are nice. Fit well and much easier to remove than my originals. Quote Link to comment Share on other sites More sharing options...
Bravoman Posted May 9, 2015 Report Share Posted May 9, 2015 And the nice thing about bladders is that if they start to leak you can add cialis to the fuel because the ad says it controls BPH! 2 Quote Link to comment Share on other sites More sharing options...
carl Posted May 9, 2015 Report Share Posted May 9, 2015 benign prostate hypertrophy . 2 Quote Link to comment Share on other sites More sharing options...
Marauder Posted May 9, 2015 Report Share Posted May 9, 2015 I don't think that that is the case, Chris. The AD dates back to January 2005 and applies to bladder installations prior to February 1998, but the caps didn't change until about five years ago. I think that the reason O&N went to a different cap design (the one that you have pictured above) was because Shaw, the manufacturer of the caps that O&N used back when you and I had our bladders installed, raised their prices exponentially and O&N could no longer affordably incorporate them into their STC. They had to find an alternative. All that having been said, a non-flush cap has always been a no-cost option with O&N, but apparently very few if any Mooney owners have chosen it. Jim Jim - you're right. The AD was originally going to force the retrofit to raised caps but was removed. The raised caps were offered as an option when the AD was complied with but I stayed with my original Shaw caps. I corrected my original post. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
takair Posted May 9, 2015 Report Share Posted May 9, 2015 I know OP has a J and asked if the caps are relocated? As mentioned, for the J, they are not. Pre J the caps are relocated one bay outboard. Pre J aircraft gain fuel capacity, even with the basic install. Quote Link to comment Share on other sites More sharing options...
carusoam Posted May 9, 2015 Report Share Posted May 9, 2015 Could we get a version of O&N's precision machined cap with lock, to fit in the nicer (OEM) ultra flush fill neck? There is something funky about the step that O&N has by mounting to the external surface of the wing. Brand P and C pilots don't have these laminar concerns... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Shadrach Posted May 9, 2015 Report Share Posted May 9, 2015 I know OP has a J and asked if the caps are relocated? As mentioned, for the J, they are not. Pre J the caps are relocated one bay outboard. Pre J aircraft gain fuel capacity, even with the basic install. I thought the F and the J had identical tanks and filler locations. Quote Link to comment Share on other sites More sharing options...
DrBill Posted May 9, 2015 Report Share Posted May 9, 2015 My caps were not relocated.. I think that the change in caps results in more capacity (54 gal vs 52) since you can fill it more. I've posted pics of my set done in 2011. Bill Quote Link to comment Share on other sites More sharing options...
rbridges Posted May 9, 2015 Report Share Posted May 9, 2015 My caps were not relocated.. I think that the change in caps results in more capacity (54 gal vs 52) since you can fill it more. I've posted pics of my set done in 2011. Bill Resize of PICT0692.JPGResize of PICT0693.JPG I believe my caps are in the same location, too. They do create another access panel on top of the wing, but the caps weren't moved. Quote Link to comment Share on other sites More sharing options...
takair Posted May 9, 2015 Report Share Posted May 9, 2015 I thought the F and the J had identical tanks and filler locations. Sorry, you may be correct. I should have stuck to C and E. 1 Quote Link to comment Share on other sites More sharing options...
rbridges Posted May 9, 2015 Report Share Posted May 9, 2015 Jim that could be correct. To be honest it's been a few years for me and I could be remembering wrong. Quote Link to comment Share on other sites More sharing options...
Hank Posted May 9, 2015 Report Share Posted May 9, 2015 Jim, I have an old memory of seeing Rob's plane, and it matches your recollection. They worked hard to match his paint job (burgundy with gold stripes). Quote Link to comment Share on other sites More sharing options...
Piloto Posted May 10, 2015 Report Share Posted May 10, 2015 I don't think that that is the case, Chris. The AD dates back to January 2005 and applies to bladder installations prior to February 1998, but the caps didn't change until about five years ago. I think that the reason O&N went to a different cap design (the one that you have pictured above) was because Shaw, the manufacturer of the caps that O&N used back when you and I had our bladders installed, raised their prices exponentially and O&N could no longer affordably incorporate them into their STC. They had to find an alternative. All that having been said, a non-flush cap has always been a no-cost option with O&N, but apparently very few if any Mooney owners have chosen it. Jim You are very right Jim. Even on the Acclaim and later models they opted not use the Shaw Aero caps. Not only are they expensive but long delivery times. I like the new style with the lock (underneath the rotating handle). José Quote Link to comment Share on other sites More sharing options...
carusoam Posted May 10, 2015 Report Share Posted May 10, 2015 That's what I was asking for, José! (In post #14) Flush mount with a refined machining tolerance. The Laminar guys will like that. The O&N surface mount just doesn't have the caché of the one you have pictured. Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Piloto Posted May 10, 2015 Report Share Posted May 10, 2015 That's what I was asking for, José! (In post #14) Flush mount with a refined machining tolerance. The Laminar guys will like that. The O&N surface mount just doesn't have the caché of the one you have pictured. Best regards, -a- The one on the picture above is used on the later LR tanks for Mooneys on those models requiring the extra filler cap. When the rivets are painted it looks really nice. I could not figure out why O&N opted for 12 screws on their caps. The O&N surface mount may be due to allow bolting it to the bladder collar. José Quote Link to comment Share on other sites More sharing options...
Guest Mike261 Posted May 10, 2015 Report Share Posted May 10, 2015 You are very right Jim. Even on the Acclaim and later models they opted not use the Shaw Aero caps. Not only are they expensive but long delivery times. I like the new style with the lock (underneath the rotating handle). José so is this the current version of cap used by o and n? Quote Link to comment Share on other sites More sharing options...
Guest Mike261 Posted May 11, 2015 Report Share Posted May 11, 2015 Jim, is the flush mount an optional thing? or is it a different manufacturer? the pic in post 2 does not look "flush" so to speak. Mike Quote Link to comment Share on other sites More sharing options...
MyNameIsNobody Posted May 11, 2015 Report Share Posted May 11, 2015 i would not... Quote Link to comment Share on other sites More sharing options...
Marauder Posted May 11, 2015 Report Share Posted May 11, 2015 i would not... You don't know how long I waited to use this line! "Nobody cares" Sent from my iPad using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
