helitim Posted March 22, 2015 Author Report Posted March 22, 2015 Erik, "As Marky_24 stated, they are a slightly rough finish. Follow his directions for sanding, labeling and clear coating. The new ones do fit a little bit better but, do not have the snug fit of the originals. What I wondered about is if the Klixon switch itself may have just a slight amount of wear that prevents the switch cover from fitting tightly. Next time I am at the airport, I am going to try a new cover on a different switch to test that theory." Still have not test fit on another switch so, not sure if wear is the problem yet. Tim Quote
Marauder Posted March 22, 2015 Report Posted March 22, 2015 Erik, "As Marky_24 stated, they are a slightly rough finish. Follow his directions for sanding, labeling and clear coating. The new ones do fit a little bit better but, do not have the snug fit of the originals. What I wondered about is if the Klixon switch itself may have just a slight amount of wear that prevents the switch cover from fitting tightly. Next time I am at the airport, I am going to try a new cover on a different switch to test that theory." Still have not test fit on another switch so, not sure if wear is the problem yet. Tim Tim -- do you what the person used as an example to make the switch? I have a defective switch I could send them to test the fit on. Quote
Danb Posted March 30, 2015 Report Posted March 30, 2015 you guys are ingenious....i put in an AOA and my switch does not match, Markies idea seems like i'll change mine so it will look original.. Quote
NotarPilot Posted April 1, 2015 Report Posted April 1, 2015 Hey Tim, have you had a chance to check the switch cover on a different switch yet? Quote
PeytonM Posted August 14, 2015 Report Posted August 14, 2015 I have an 89J, and from reading the Shapeways website, these are the later model E-T-A switches, so I ordered two: one to "experiment" on and one for installing. For labeling, did you make one single long label "STROBE LITE- PUSH ON- STROBE LITE? Width of the label the same as switch? Did you paint the switch after sanding? Flat or glossy? Quote
