SuperPilot Posted February 23, 2015 Report Posted February 23, 2015 Hey guys, been having this issue since shortly after getting my 1978 M20J model. Check the video out, the fuel pressure will read steady on the ground and sporadically in flight then do what is displayed in the video. Already had the Fuel pressure sending unit replaced which did nothing and just had the engine overhauled so when the engine was reinstalled I had them check the grounds for the gauges. Thanks for any help! - Garrett IMG_0839.MOV
ArtVandelay Posted February 23, 2015 Report Posted February 23, 2015 I would think the gauge is broken, don't know if they can be repaired or replaced.
carusoam Posted February 23, 2015 Report Posted February 23, 2015 Unable to see video on my iPad...? -a-
flyboy0681 Posted February 23, 2015 Report Posted February 23, 2015 Hey guys, been having this issue since shortly after getting my 1978 M20J model. Check the video out, the fuel pressure will read steady on the ground and sporadically in flight then do what is displayed in the video. Already had the Fuel pressure sending unit replaced which did nothing and just had the engine overhauled so when the engine was reinstalled I had them check the grounds for the gauges. Thanks for any help! - Garrett Mine does identical thing, fine on the ground, and once in flight is pegged to the right.
SuperPilot Posted February 23, 2015 Author Report Posted February 23, 2015 For those that can't view the video it just starts fluttering all the way off the scal and then will peg all the way on the upper side in the black. Would that be a symptom of a potential bad sending unit?
ArtVandelay Posted February 23, 2015 Report Posted February 23, 2015 Unable to see video on my iPad...? -a- No problem with my mini, with IOS ver 8.1.3
carusoam Posted February 24, 2015 Report Posted February 24, 2015 Hmmmm, IOS 8.1.3 as well, still no/go... Message says 'loading' Best regards, -a-
ArtVandelay Posted February 24, 2015 Report Posted February 24, 2015 It needs to say it's downloaded, might be a Tapatalk issue I'm on an older version
