carusoam Posted January 18, 2015 Report Posted January 18, 2015 Very nice WishBone! What caused the the shakes on final approach? Is that turbulence? Is it more a wing tip magnified turbulance? Best regards, -a- Quote
wishboneash Posted January 18, 2015 Author Report Posted January 18, 2015 Thanks. The vibration is due to some kind of natural resonance/engine rpm amplified by the wing (tip mounted GoPro). Not apparent inside the aircraft. Quote
TTaylor Posted January 18, 2015 Report Posted January 18, 2015 Beautiful video. In the future please consider climbing a few more thousand feet as you are crossing the high ground between Placerville and TVL. At 4:00 on the video an engine failure would leave you no options. Quote
bonal Posted January 18, 2015 Report Posted January 18, 2015 Started to watch earlier today but now I can't get it to load Quote
lahso Posted January 18, 2015 Report Posted January 18, 2015 Nice video. That's beautiful country out West. Quote
bonal Posted January 18, 2015 Report Posted January 18, 2015 Got it to work that time very nice vid. LVK is my most visited field very familiar departure. Thanks for sharing. Wishbone ash is that after the music group I knew there was something wrong with that spelling. Don't want to get scolded by the spelling guy. Quote
N201MKTurbo Posted January 18, 2015 Report Posted January 18, 2015 Why do people have to criticize how other people fly? Takes all the fun out of it. 5 Quote
wishboneash Posted January 18, 2015 Author Report Posted January 18, 2015 Thanks for the positive comments! Yes, Wishbone Ash is the classic rock group from England. I am letting Youtube to process the video to stabilize it, let's see how that looks to remove the "oscillations" at the end. I was at 11,500 ft and didn't want to climb over the puffy whites, but found the gaps and descended to 9,500 over CA-50. Had head winds of 30knots and took me 1hr 5 min for this flight. Surprisingly, there was little or no turbulence. Quote
bnicolette Posted January 18, 2015 Report Posted January 18, 2015 Beautiful video & scenery! Â Thanks for posting. Quote
Oscar Avalle Posted January 19, 2015 Report Posted January 19, 2015 Well done. Very nice scenery! Quote
kmyfm20s Posted January 19, 2015 Report Posted January 19, 2015 Beautiful video. In the future please consider climbing a few more thousand feet as you are crossing the high ground between Placerville and TVL. At 4:00 on the video an engine failure would leave you no options. Is there a better patch of pine trees you know about with a little further glide? 2 Quote
Joe Zuffoletto Posted January 19, 2015 Report Posted January 19, 2015 Thanks for the video fix. I've been grounded way too long by work, aircraft mx and weather! Quote
wishboneash Posted January 19, 2015 Author Report Posted January 19, 2015 Thanks all for the nice feedback. Encourages me to do more of these! The scenery indeed is spectacular especially this time of the year. Quote
bonal Posted January 19, 2015 Report Posted January 19, 2015 Adding a few thousand would only prolong the terror. I do like to climb as high as possible for more options and I am always looking down and trying to pick out best choices sometimes if the engine quits it's just going to suck real bad. Question about the video, what is the rounded shape on the bottom of the view? The fog is lifting hope to fly soon. Quote
wishboneash Posted January 19, 2015 Author Report Posted January 19, 2015 Adding a few thousand would only prolong the terror. I do like to climb as high as possible for more options and I am always looking down and trying to pick out best choices sometimes if the engine quits it's just going to suck real bad. Question about the video, what is the rounded shape on the bottom of the view? The fog is lifting hope to fly soon. Â It has been LIFR to IFR for most of the morning/early afternoon here at LVK for past few days. Re: the rounded object perhaps you are seeing the vertical fin separating the wingtip fairing from the main part of the wing? Quote
AndyFromCB Posted January 19, 2015 Report Posted January 19, 2015 Beautiful video. In the future please consider climbing a few more thousand feet as you are crossing the high ground between Placerville and TVL. At 4:00 on the video an engine failure would leave you no options.  There are quite a few areas in the Rockys and Sierras, where short of being at FL250, your options are pretty limited. Even at FL250, you better know where you're going right away and know the winds too. At 90knots, 30knot headwind really eats into horizontal distance covered. Quote
DaV8or Posted January 19, 2015 Report Posted January 19, 2015 Bummer. I thought I might see my house in your video, but I didn't make the edit. Quote
kmyfm20s Posted January 19, 2015 Report Posted January 19, 2015 What field of view did you have your camera set at? I Just took a video from my recent flight and it just didn't seem to capture the view as I saw it in the plane. Any of you video guru's can jump in on some recommended camera setting I would appreciate it. Great video! Quote
wishboneash Posted January 19, 2015 Author Report Posted January 19, 2015 Correction: I used the 1080p 24fps Medium field of view in the GoPro 4 Silver 1 Quote
kmyfm20s Posted January 19, 2015 Report Posted January 19, 2015 Thanks. Do you know if it was N, M, or W field of view? Quote
Oscar Avalle Posted January 19, 2015 Report Posted January 19, 2015 I would use the M setting. Otherwise you get too much of a distorsion. 1 Quote
wishboneash Posted January 20, 2015 Author Report Posted January 20, 2015 Thanks. Do you know if it was N, M, or W field of view? Â It was the M setting - I corrected my original post as well. Quote
47U Posted January 20, 2015 Report Posted January 20, 2015 That's great video... Looking forward to your next edition. Sure wish we had more snow in the mountains. There's time yet, but we're behind with the white stuff. Quote
