I do not off the top off head. however any breaker that meets the amperage should work
I guess it depends on if you want to log it. If its not the original part you'd need a PMA, TSO, etc that says its ok for use in your application. At least if you're going to log it.,
-Robert
601 is right. Standard parts need no TSO or PMA. In fact, you can substitute wheel bearings, electrical parts, belts, and bulbs under the faa's aging aircraft program.
