I got 50$ it is a slick mag. For some reason, slick impulse mags are failing pretty regularly.
Quite right. In fact my mechanic recommended an overhaul rather than new due to the poor quality of Slick post purchase by Champion.
Yep. We just had a 172R In the shop. It had 200 hour since new slick mags on it. At 100 hrs it wouldn't start, they changed te harnesses, the plugs, all at great expense and at 200hr we got it. Slick mag failure. Wouldn't make a spark.
For about 300$ more you can put Bendix 1200s on there and solve the mag problem for good
Had the same problem two weeks ago left mag failed after 300 hrs (from last 500 hr check)...yep it was left impulse coupled slick mag that mag shop in Redding identfied slow speed misfire ....did 500 hr and replaced coil.....seems to be a bad batch of Slick coils...normal high speed runup though..kpc
Sounds like some great trouble shooting by the previous shop, the owner must be thrilled.
