epsalant Posted July 12, 2010 Report Posted July 12, 2010 I have a 1989 M20J and was always taught (and have confirmed in the POH) that Vfe is 115 KIAS, as indicated in the POH page 2-3. But on page 5-7 of the POH there is a graph labeled "AIRSPEED CALIBRATION-PRIMARY STATIC SYSTEM-FLAPS/GEAR DOWN" indicating that 15 degrees of flaps may be lowered safely at 128 kts! This isn't mentioned anywhere else in the POH, and I've read the whole book !!! I don't know if it is a mistake on the graph or an omission from the rest of the POH. Any thoughts from experienced M20J drivers/mechanics ? Thanks Evan Quote
carusoam Posted July 12, 2010 Report Posted July 12, 2010 From the type certificate..... (posted by MJC on another thread) http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/2fb25685d0303ab1852567ed004f59b8/$FILE/2A3.pdf IX. Model M20J, 4 PCLM (Normal Category); Approved September 27, 1976 Engine Textron-Lycoming IO-360-A1B6D or IO-360-A3B6D or IO-360-A3B6. (Bendix fuel injector, Model RSA 5AD1, P/N 2524054) See Note 12 and Note 20. Fuel 100LL or 100/130 octane minimum grade aviation gasoline Engine Limits For all operations, 2700 r.p.m. (200 hp) Airspeed Limits Maneuvering 136 m.p.h. (118 knots) IAS Never exceed 200 m.p.h. (174 knots) IAS * **** Flaps extended (full flaps) 127 m.p.h. (110 knots) IAS Landing gear retraction 110 m.p.h. ( 96 knots) IAS (15° flaps) 145 m.p.h. (126 knots) IAS Never exceed 225 m.p.h. (195 knots) IAS This seems to be a slightly different answer than you posted. Interesting source of information. Check the original link for accuracy. The cut and paste is not identical to the original. Best regards, -a- Quote
epsalant Posted July 12, 2010 Author Report Posted July 12, 2010 hmmm...that's certainly not what the 1989 M20J POH says. But in any case, I'm just wondering if there is a higher flap speed limitation (as indicated in the POH graph that i posted) with 15 degrees of flaps. Evan Quote
Royski Posted July 22, 2010 Report Posted July 22, 2010 I reckon the plane could handle higher speed flap actuation, but I imagine it is harder on the equipment. Personally I aim for lower airspeed actuation of gear and flaps in my M20J. Quote
GeorgePerry Posted July 22, 2010 Report Posted July 22, 2010 I've always just used the top of the white arc on the A/S indicator. The way the airspeed needle jumps around in most small GA planes, +/- 2 or 3 knots is about as accurate as you can hope to get. Quote
fantom Posted July 22, 2010 Report Posted July 22, 2010 Quote: GeorgePerry I've always just used the top of the white arc on the A/S indicator. Quote
